It is currently Sun Nov 02, 2025 2:35 am
PostPosted: Tue Dec 26, 2006 3:07 pm
question for you guys
i have in the past installed a mitsu rubber plug for a bs elimination...and i coverd the whole thing in JB weld to ensure it didnt fall out....
well a few months later it did fall out....
so what do you guys use for a plug....the ol metal freezeplug? rubber? something else?
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Tue Dec 26, 2006 5:41 pm
I've never done the BS elimination, but from what I've heard, freeze plugs work very well. I'd imagine that using a soft brass one would work the best as it will deform and not break the surrounding aluminum on the hole.
...and JB weld sucks. Even an expandable rubber freeze plug would be better.
PostPosted: Tue Dec 26, 2006 6:37 pm
I have used both rubber coated and aluminum, never had a problem with either, I used rtv on the rubber coated one, and jb weld on the al. one. All of the plugs I installed fit pretty tight as well.
PostPosted: Tue Dec 26, 2006 8:55 pm
I like the rubber
If it was installed correctly- and still came out, it sounds like you had excess crankcase pressure issues.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Tue Dec 26, 2006 10:33 pm
I like the rubber
...maybe the car did have 155 psi across the board
i dunno though it wasnt my car...however now i am rebuilding my car and i really don't like pulling front covers because of stupid shit like that :)
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Tue Dec 26, 2006 10:37 pm
I seem to remember switching broken lower oil pump housings from my cracked 1.6 unit (my fault) to the 1.8 Hyundai unit. I also switched the oil pump unit from both pumps, and had to remove the balance shaft kit from the 1.8 cover. So, I also had to remove the plug from the 1.6, but for the life of me, cannot remember what is holding it in there, anybody have a link to a pic of this little plug?
PostPosted: Tue Dec 26, 2006 10:40 pm
Never had a probleam with the rubber plug use just a dap of RTV. If I am buying a new front case i get the 1.6l case as its already eliminated from the factory.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
PostPosted: Tue Dec 26, 2006 11:01 pm
Never had any issues with an inverted freeze plug laced in JB weld
PostPosted: Wed Dec 27, 2006 1:14 am
I like the rubber
I agree!!
Current
08 535ix 420awhp
PostPosted: Wed Dec 27, 2006 1:51 am
$.77 freeze plug from mitsubishi with JB weld.
Steven
1985 Mitsubishi Cordia
Build in progress
PostPosted: Wed Dec 27, 2006 2:31 am
well i havnt even checked my oil pump yet to see what it looks like
if i need a new pump ill prolly just pickup an entire 1.6 front cover
which way did you guys install the rubber plug.... lip facing towards trans or lip facing towards t belt
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Wed Dec 27, 2006 11:48 pm
Rubber face toward the trans-in, metal side faces out.
Corey
