It is currently Mon Nov 03, 2025 2:05 am
 Post subject: TD04-11B CFM rating?
PostPosted: Sat Sep 23, 2006 8:54 am
Hey,
Just wondering if anyone here knows what the CFM rating is for the 11B turbo? I've have the rating for the 9B and 13G, but can't for the life of me find the 11B rating. :evil:
It is needed for a turbo specs tech post that is being prepared over at 4G61NZ so any help would be appreciated.
Thanks
PostPosted: Sat Sep 23, 2006 10:56 am
You're probably looking at the same website that I'm looking at to get your turbo flow rates. The one from Vfaq right? I says the 9B flows 265cfm and the 12A flows 320cfm, so I'd have to imagine the 11B is somewhere in that general area for flow. I can't give you an accurate number though. These flow numbers are fairly arbitrary anyways, it depends greatly on how much boost the person is running.
PostPosted: Sat Sep 23, 2006 6:21 pm
Yeah, we're just looking for the info to add to a "Tech Gold" Turbo thread i'm putting together for 4G61NZ. Would be nice to have the stock 4G61T turbo there as a comparision. CFM Ratings tend to be at 15psi which makes the comparisons semi relevant.
If anyone can confirm that the RVRs also came with 15Gs and their cfm ratings that'd be great. I can only find Volvo or aftermarket TD04HL-15G information.
www.4G93T.net | www.4G61NZ.co.nz | www.SquidInc.co.nz | <RR>
PostPosted: Mon Jan 15, 2007 7:50 pm
Bump, can anyone help us? :cry:
PostPosted: Wed Jan 17, 2007 12:37 am
:x Wish I had more to add. It's not the most hotly debated topic, even at the best of time unfortunately. Someone will see this SOS go up.
