It is currently Mon Nov 03, 2025 4:28 pm
 Post subject: shift cable problems!!
PostPosted: Wed Apr 04, 2007 10:00 am
hey guys, im sure this has been asked before but i couldn't find anything on it. i originally had a 1.5 5 speed tranny mounted to my 4g61t but i recently switched to the 1g fwd tranny. the cables are incompatible.. one cables throw is too short.. i found some 1g non turbo shift cables and they work ok.. but im having 1st and 2nd gear grinding problems because of it.. if i remember correctly the colt turbo cables will work but i cant find any... any answers will be greatly appreciated.. thanks
PostPosted: Wed Apr 04, 2007 10:27 am
You need to swap the shift levers on the tranny, not the cables. Either that or modify a dsm shifter to fit. There is some info in the archives.
PostPosted: Wed Apr 04, 2007 8:38 pm
i understand.. your suppost to swap the levers from the 1.6 tranny but i have a 1.5 tranny .. the levers are different...im using a dsm shifter
PostPosted: Wed Apr 04, 2007 10:39 pm
Colt turbo cables are the same as 1.5L cables.
PostPosted: Wed Apr 04, 2007 10:45 pm
If you're using a dsm shifter and tranny there shouldn't be any problems.
PostPosted: Thu Apr 05, 2007 8:20 pm
So the right setup would be the colt cables and the dsm shifter with a dsm tranny correct?
PostPosted: Thu Apr 05, 2007 10:15 pm
colt cables
colt shifter
colt shifter arms
dsm tranny
