So, you didn't feel the need to do this "before" the motor went into the engine bay?
That's what I was thinking...But anyway, yeah you have the procedure down. It was tight as hell on my talon so I can only imagine how little room there is on a CSM for a timing belt change. Don't forget to do the water pump too while you're in there. Good Luck with it!
Oh yeah, make sure all marks line up including the balance shafts. If one of those doesn't line up keep turning the engine until it does. If it isn't done correctly your engine will vibrate due to the balance shafts being out of time and the job will have to be redone. I know you don't want to hear this but I would have eliminated the balance shafts while the engine was out.
