It is currently Mon Oct 27, 2025 2:35 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Nov 25, 2008 2:40 am
:rolleyes: I will try it tomorrow and report back. Thanks for all your help so far.
PostPosted: Tue Nov 25, 2008 4:52 am
regarding the tacho mod:
when using a 91+ ecu with a GT harness the tach goes up the muck (i am not a expert on converting JDM to USDM so i probably have years wrong)
what fixes the tach problem is
re-wiring to the later model PTR, run the PTR tach output to the ECU
keep the Tacho Interface Unit and run that directly to the dash
Problem solved.
PostPosted: Tue Nov 25, 2008 11:53 pm
having the same problem! But.. I might have found out something interesting.
Attached is a picture of what I rewired. I'm not sure it's correct, but it's all i could find.
I put the 94 e-prom in... same thing happened.. want to rev up then die. rev up then die back down. but the tach was working still? I thought the tach wouldn't work if i rewired the two wires. I also put the old 90 ecu in the bad one, and it started up and did the same thing and the tach worked still?
Did i rewire the wrong 2 wires? This harness doesn't have a solid green 14 wire.
PostPosted: Tue Nov 25, 2008 11:54 pm
The 14 wire was green with a red line on it. The 6 was green with a white line.
PostPosted: Tue Nov 25, 2008 11:59 pm
Not sure what I think about recent discovery. I switched the ecu to a 1.6L ecu and it revs up fine?!
I must have switched the wrong wires above. Could someone please advise. I might be getting somewhere now.
Tach works on 3 ecus though.
PostPosted: Wed Nov 26, 2008 12:13 am
It's wierd because if it's the other way, like i thought it should...
Black would be 6 and blue would be 14
PostPosted: Wed Nov 26, 2008 12:25 am
Blue..
Black..
What do you guys think? I tried to go by color, because that's what vfaq said, even though they are in opposite locations. I think this is the way to go.
PostPosted: Wed Nov 26, 2008 12:44 am
switched the wires to the blue / black wire and things are working now. I can't really go drive it because my neighbors are a sleep and it has no exhaust. But I think the problem might be solved!
PostPosted: Wed Nov 26, 2008 1:00 am
drove around the block just fine. poor neighbors. also, i'm going to try the other ecu tomorrow to confirm if it's good and is just a 91+ board. Oh ya.. My tach also works perfect on a 94 ecu.
