It is currently Tue Jun 04, 2024 8:41 am
PostPosted: Sun May 03, 2015 11:37 pm
Can anyone tell me if a 1g aftermarket clutch line from the master cylinder to slaver cylinder will work in a 4g mirage with the stock mirage master cylinder and 1g trans? Or do the 1g master cylinder and 4g have different line connection at the master cylinder?
I don't like the way my setup is currently with a mix of both 4g line and 1g line so I'm just looking for an alternate route.
PostPosted: Mon May 04, 2015 8:01 am
One from a 1g dsm will work fine. It may be too long but you can just route it a little different or loop it.
PostPosted: Mon May 04, 2015 5:18 pm
Yup, 1G line is really long. I have it looped in the engine bay. Ideally you would run it front the master, across the firewall, down the passenger side frame rail and then over to the slave. Otherwise you will have what I found, and that is rubbing on the axle shaft when you discover your last loop wasn't tightened high enough.
PostPosted: Tue May 05, 2015 3:13 pm
nice, thanks guys, as always good quick responses even if i get side tracked and cant check back quickly lol
