http://forum.4g61t.org/viewtopic.php?t=4447
whoops
________________________________________________
To begin the install you will need to start off with modifying one part.
The coolant feed line, part# MD140476, is not going to fit and needs to be cut. Then entire middle section needs to be removed so you can use the two separate ends. Where you cut it will depend on how you want to attach your new coolant hose. There are two ways to ensure your hose will stay mounted when you put it on. Either have the pipes beaded or flared. If you plan to bead it either with a bead roller or running a
line of JB Weld on the pipe, I recommend cutting the pipes about the middle of the bend. That way it gives some direction to the hose. If you plan to flare it you'll need to cut it so all you have are straight sections. A flaring tool wont work otherwise. You also dont need to flare the pipes anymore than 1/16. In the end you should only need about an 8" section of 3/8 coolant/fuel hose to complete your new coolant feed
line.
kno i saw this somewhere...is it possible to just hacksaw this thing and connect with hose and some hose clamps? must it be beaded or flared?
is this ABSOLUTELY necessary? if not, imma finish this by tonite!
thanks
