It is currently Fri Apr 19, 2024 6:15 am
 Post subject: 4g63t with ac?
PostPosted: Tue Sep 27, 2011 9:38 am
Has anyone did a 4g63t swap in a 4g mirage/summit/colt and still have ac??
 Post subject: Re: 4g63t with ac?
PostPosted: Mon Nov 07, 2011 9:17 am
Why are you asking this question? If you're looking to do this it should bolt right up. I kept the ac in my 93 colt van. It bolts right up easy. Kind of a good question cause most swaps didnt have air to begin with, and the other ones get deleted. I am not knowledgable enough to answer this, but the way mitsu is they make all their stuff interchangeable.
PostPosted: Tue Nov 08, 2011 2:17 am
A/C, P/S, Cruise, PTE FMIC, AWD, crash bar, steering cooler, OEM type fans, etc, etc...
It all fits.
PostPosted: Tue Nov 08, 2011 10:06 am
As he stated above, and you can visit mirageforums.net because they have all 4G+ cars there.
PostPosted: Thu Sep 27, 2012 5:11 pm
Actually this is a good question.
My 1.8 LS has the A/C unit mounted on the front side of the motor whereas, 1G's have theirs mounted
on the backside.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Thu Sep 27, 2012 5:24 pm
Maybe use the dsm compressor and have someone tig up some hybrid lines using lines from both cars?
PostPosted: Wed May 28, 2014 3:22 pm
More likely none of the above. I've done this job on my 4G coupe. Issues are:
* the R1134A (not the earlier R12) evaporator, condenser, drier canister can be used, plus the various 4G relays and controls in the center dash panel. The wiring is mostly all there except for the relays assembly that installs next to the power steering reservoir.
The compressor is the issue. The older R12 bits are not usable, so either the Talon or 4G 1.5L compressor has to be used. The 1.8L compressor is different and mounts on the front of the engine.
* Talon: direct fit on to the engine. Talon and 4G connector pipes are different sizes vs the 4G, and the hoses are different.
* 4G 1.5: the Talon mounting bracket has to be modified to mount the 4G compressor. The belt pulley is the wrong size and does not line up with the 4G63 belt. This can be fixed by using a 4G63 water pump pulley, with a spacer to align the belts. The new pulley size runs the compressor at about the same rate as the 4G installation. You can work this out by comparing the respective pulley diameters and doing the math.
* hoses: the 4G hoses from the compressor to the firewall don't fit the new position of the compressor on the 4G63. I had an AC shop rehose the existing connectors/pipes, which requires TIG welding suitable hose tooth sections, so the hoses would not leak when clamped. The shop also pressure tested the hoses.
My condenser rad was not leaking (many do with age) so a new drier was fitted, the system was evacuated, and new refrigerant loaded. Works fine.
SD
PostPosted: Thu Jul 10, 2014 10:05 pm
Yes, back in 04. Its a a 63 NA car we did.
AC. PS, blew cold. :) Used a 2.0 Compressor-tig welded talon lines with Colt lines-used Colt dash wiring. Worked well and had no issues.
Side note-to this day that was the ONLY Colt I have ever seen in Light Yellow Pearl. As ghey as that sounds one of the best Mitsu factory colors I have ever seen.
http://www.clublexus.com/gallery/data// ... 374834.jpg
But on a Colt. Mitsubishi Martinique Yellow Pearl
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Thu Jul 10, 2014 10:58 pm
I saw a 4g coupe at the JY in that color a while back. It was gone the last time I went though. They are pretty rare though, only one I've ever seen.
