It is currently Thu Apr 25, 2024 4:10 pm
 Post subject: Poly Mounts
PostPosted: Thu Apr 21, 2011 1:42 am
so for the 4g63 swap ive got a stock 93 colt transmission mount here (rubber mount that bolts to the passenger frame rail) and it seems to look similar to the dsm one
can i use this mount for the swap?? and if i do, i planned on installing some poly bushings. Would the dsm bushing fit into this mount?
 Post subject: Re: Poly Mounts
PostPosted: Thu May 05, 2011 8:39 am
If I remember I think you use the stock mount that bolts to the frame and then the stock mount that bolts to the trans and then just redrill a hole for the two to be bolted together. Don't quote me though, this is from what I've read. lol
PostPosted: Mon May 09, 2011 11:00 pm
Do you mean the stock mirage/colt transmission mount that attaches to the frame rail? mine looks diffrent than the one you posted... ive got the stock 1.5 transmission bracket bolted to my awd transmission just fine. i had to take a hack saw to one of the pegs and then tap the hole a little further but it works fine.
