It is currently Fri Apr 19, 2024 7:38 am
 Post subject: fuel psi ?
PostPosted: Tue Apr 14, 2009 9:00 pm
So mods are... 16g.550's custom front mount 10lbs of boost gm mass air 3" with MaFT... and fuel pressure is 40psi at idle and wot 30lbs .. the car doseint brakeup anymore due to me fixing all the rusty ground and hacked up wireing install...
Is 30psi to low ?
I was thinking of puting in a walbro but just wanted to check
 Post subject: Re: fuel psi ?
PostPosted: Tue Apr 14, 2009 9:28 pm
Is 30psi to low ?
You're not supposed to have LESS fuel pressure at WOT than at idle. It's supposed to go up with boost. Either there is something wrong with your fuel pump, or your regulator, or both.
PostPosted: Tue Apr 14, 2009 10:13 pm
Is 30psi to low ?
looks like its time for a walbro and a fuel rail and a reg... ughh.. o well dsm fun.
I sware this dsm is costing me more then my regal.
Last edited by rollinunknown on Tue Apr 14, 2009 10:15 pm, edited 1 time in total.
PostPosted: Tue Apr 14, 2009 10:14 pm
Is 30psi to low ?
You can leave the rail and regulator alone, just upgrade the pump.
PostPosted: Sat Apr 18, 2009 12:30 am
Your fuel pressure should be around 42 at idle, and go up from there. If it decreases, you need to check to see if your vaccuum lines are properly connected, and that there isn't some kind of leak. I would not drive the car until you find the issue especially since it appears that the car is having a lean condition when you are in boost. If you don't sort it out, then you'll be paying for more than fuel upgrades.
PostPosted: Mon May 18, 2009 11:22 pm
http://www.wheelsjamaicahost.com/wheels ... oard=111.0
just to give you guys an idea of whats going on in Jamaica :weedman: :weedman: with 4th Gens especially
We got Evolutions :prayer: :prayer: here since the original :finga: :finga: so if you guys need any info and "JDM" stuff you can look us up
plus yo ucan always come for the racing :axe: :axe: and stay for the girls :heart: :heart:
