4 bolt rear end http://www.4g61t.org/forum/viewtopic.php?f=57&t=28372 |
Author: | awdcsm [ Fri Mar 20, 2009 12:55 pm ] |
Post subject: | 4 bolt rear end |
if i want to up my 3-bolt rear end to a 4bolt, if i cant find a 92-94 1g 4-bolt rear end is it possible to use a 2nd gen rear end? also what are all the parts i will need to collect to convert it to a 4bolt rear? |
Author: | CaptainTonus [ Fri Mar 20, 2009 1:49 pm ] |
Post subject: | Re: 4 bolt rear end |
Quote: if i want to up my 3-bolt rear end to a 4bolt, if i cant find a 92-94 1g 4-bolt rear end is it possible to use a 2nd gen rear end?
No, a 2g rear-end is totally different, doesn't use axle cups and flanges like a 1g rear-end, the axles goes straight through the hub.
Author: | canada4g63 [ Sat May 02, 2009 3:46 am ] |
unless your making alot of power i'd run the 3bolt until you bust it. just my 2cents |
