It is currently Tue Jun 04, 2024 4:01 am
PostPosted: Tue Dec 30, 2008 9:02 pm
Since I couldn't find a good set of rear lower control arms for the AWD conversion in the mirage, I made my own. Made a sleeve that the factory ball joint will press into, then added the tube & threaded end. A heim end will make up the inner pivot point, so it will be adjustable. everything is chromoly, I was worried it would be heavier than the factory unit, but it's 1-lb lighter. Just need to finish the swaybar mount..
scot
PostPosted: Tue Dec 30, 2008 10:45 pm
Wow. I've actually wondered if anyone had tried this before. I can't stand the stock lower control arm, its gay as hell. The stock cam bolt for that thing breaks the rim on the subframe, and the bolt/nut usually rusts all to hell too. What is your opinion on running no sway bar, say for a car running in straight lines usually?
PostPosted: Tue Dec 30, 2008 11:24 pm
no rear sway bar for str-8 line stuff would be no problem..
scot
PostPosted: Wed Dec 31, 2008 8:23 am
Note to self, Scot is really good at welding metal together. 8)
PostPosted: Wed Dec 31, 2008 4:37 pm
dudes a robot, perfect c's in all the places I see.
PostPosted: Wed Dec 31, 2008 4:46 pm
If the rest of your swap has the same quality work I can't wait to see it. Great job!
PostPosted: Thu Jan 01, 2009 7:47 am
scot, i sent you the corners....oh can you make these to replace the stock ones, freaking welding machine !
PostPosted: Mon Jan 05, 2009 9:54 pm
can i have some? :D
PostPosted: Mon Sep 07, 2009 1:00 pm
Hey Scot, did you ever get these figured out?
