It is currently Tue Jun 04, 2024 10:13 am
PostPosted: Thu Sep 06, 2007 1:04 am
Basically I am buying an AWD gas tank and driveshaft in the next few weeks. Is the sending unit different from FWD to AWD cars? Thanks, mark
91 Galant VR4
PostPosted: Thu Sep 06, 2007 1:41 am
its off a 91 talon, but I did some research and looks like they are different so I will be picking it up!
91 Galant VR4
PostPosted: Thu Sep 06, 2007 10:53 pm
much different. awd, fwd, and gvr4 are not compatible in anyway.
PostPosted: Fri Sep 14, 2007 7:00 am
:( Clarification, please. I was just getting ready to buy a '91 Eclipse AWD gastank. I had assumed that my fuel pump (Walbro 250 from my old tank) and sending unit would work. I thought that this would be better than a fuel cell. Are you saying that my old sending unit and companion fuel pump will not fit the AWD tank? Should I use the sending unit from the AWD gastank? Should I put the Walbro into the AWD fuel pump frame? Thanks.
PostPosted: Fri Sep 14, 2007 8:42 am
fwd tank must use fwd sender, awd tank must use awd sender, gvr4 tank must use gvr4 sender
PostPosted: Fri Sep 14, 2007 9:26 am
OK. Got it. :-? Just wondering, as to whether the FWD dashboard fuel guage will be accurate (within reason) using the AWD tank and sending unit. It seems that it would, but I just wonder. Thanks for saving me some irritation.
PostPosted: Fri Sep 14, 2007 9:27 am
works fine
PostPosted: Fri Sep 14, 2007 3:11 pm
:evil: Oh holy irritation Batman, my so-called AWD tank source proved unable.nmnm I gues I'll try the wanted section.
PostPosted: Fri Sep 14, 2007 6:17 pm
Got a tank for you Bill!!! 89ColtGT is picking up an AWD GSX tomorrow, and I'm sure he can send you the tank and sender!!!!!
PM him right now!!
Geoff
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Sep 26, 2007 6:40 pm
On the AWD tank, the fuel pump and sender are mounted together on one holder in the tank. They are connected to a circular top entirely different from our usual pentagon shaped device.
PostPosted: Wed Sep 26, 2007 7:03 pm
Pump differences:
www.vfaq.com
fuel section
1G AWD pump assembly
1G FWD pump assembly
Geoff
89 2.0 Turbo Colt
PostPosted: Sun Dec 23, 2007 9:00 pm
Not to hijack the thread but why does my 94 colt AWD have what appears to be 2 pumps?
PostPosted: Sun Dec 23, 2007 10:40 pm
What is your location per the rules when you join the site and can you take a picture of your fuel pump assembly or get one off the net to show those of us that don't have one apart, what you are referring to.
PostPosted: Sun Dec 23, 2007 11:31 pm
Pump = 1
level gauge/sender = 2
