It is currently Thu Oct 23, 2025 9:08 pm
 Post subject: Rear strut and spring
PostPosted: Sun Mar 18, 2007 4:38 am
We are in the middle of this swap here. The owner is looking to use the stock CSM or stock DSM rear assemblies. What can we expect from ride heigth here? Can we even do this? Does the owner need a coilover of some kind.
I know all the answers for coilovers in the rear, both FWD and AWD, but haven't come across anyone who has done this with stock stuff.
Steven
1985 Mitsubishi Cordia
Build in progress
PostPosted: Sun Apr 08, 2007 9:45 am
I;d sugest a coil-over, basicly from what we have gathered here the stock C/S/M's shockes are longer the the DSM and they are still a inch or so too short, some have sugested "blocking" the top of the shock to lower the shock otheres sd they would make a adjuster at the bottlm with a few different mounting positions.
Hope this helps.
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Sun Apr 08, 2007 3:39 pm
Biglady,
Use stock CSM struts and a coilover of some sort if you can with a decent length spring. Just try to maintain the stock CSM overall length if you can. I am on Konis for CSMs and run a coilover with a 10" eibach. The rear is in place with the wheels on the car but it has yet to hit the ground. From what I can tell the height should be perfect. As soon as it does hit the ground pics will be posted.
PostPosted: Mon Apr 16, 2007 12:34 am
For my car, I used Colt Koni yellows, and stock 1g awd springs. End result ride height looks like this:
http://home.tiora.net/davidc/Colt/AWD%20Swap/g.JPG
PostPosted: Sat Apr 28, 2007 1:24 am
We just ended up using the stock CSM suspension. It was the tallest of all we had here. Seems to work. Just will be soft. Going to be interesting with 550whp and stock CSM suspension.
Steven
Build in progress
