It is currently Mon Nov 03, 2025 4:16 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Tue May 22, 2007 4:05 pm
That's the only thing that is not installed. I will hook it up when I get a chance. Maybe that has something to do with it.
PostPosted: Thu May 24, 2007 8:25 pm
I had this problem on the Excel after I'd reinstalled the tank. Turned out I'd wedged the vent line which was stopping the air from escaping and it was instead bubbling up the filler tube.
I can see that there is next to no chance that your vent tubing is blocked but I notice that tank is a little worse for wear: have you tried blowing through the vent line to make sure it is not blocked internally?
PostPosted: Thu May 24, 2007 10:47 pm
I can blow air into and suck air out of the tank via the vent line.
Is there a chance that my angles just aren't cutting it? The gas is not able to fill into the tank quick enough?
PostPosted: Sat May 26, 2007 11:40 am
Seasoned Member
Just from looking at these pictures
http://www.lilevo.com/lilevo2/gasfiller/DSC00982.JPG
http://www.lilevo.com/lilevo2/gasfiller/DSC00983.JPG
I would say that you need to incrase the angle going to your tank quite a bit.
PostPosted: Sat May 26, 2007 12:39 pm
I did increase the angle more and upgraded the size of that last bend to a 2.0" stainless mandrel bend.
Stock tanks seem to go straight down and 90 right into the tank. Guess I'll have to put a fuel filler in my trunk. Ugh.
PostPosted: Sat May 26, 2007 12:41 pm
Dude, that would be sweet! You could be like an old-school Corvette with the gas filler in the middle of the trunk. 8)
PostPosted: Wed Jun 06, 2007 9:47 am
Seasoned Member
Fixed yet?
PostPosted: Wed Jun 06, 2007 5:12 pm
Not yet. I'm going to toss on that blue one way valve (at the tank for the charcoal canister) and try again.
When I unscrew the gas cap, there is no whooshing pressure. Maybe that has something to do with the positive pressure of the fuel in-air out while pumping.
PostPosted: Thu Aug 09, 2007 2:08 pm
This is still an issue. I installed the blue one way valve. I re-piped the piping to the fuel filler with stock sized hard pipe and wide bends. Still immediately overflows.
I got pretty pissed so I did this.
http://www.lilevo.com/lilevo2/gasfiller/part2/
now its even WORSE. WORSE!! It instantly clicks the pump off, I can barely get .25 gallons dispensed. What am I missing here???? There are NO restrictions
PostPosted: Thu Aug 09, 2007 3:08 pm
Boggels my mind. Should work awesome the way you have it set up.
- Works in da bush
PostPosted: Thu Aug 09, 2007 4:15 pm
Fixed! I pulled the whole tank and checked all the lines. I thought the vapor line was the most important line for air exit. Turns out the hard line on the very top of the tank with that blue valve on it was clogged with a pebble. I cut the line after the clog, put everything back together and it works flawlessly.
The top line is where the air evacuates from, not the vapor line which I thought.
PostPosted: Thu Aug 09, 2007 4:16 pm
Nice job. I was going to respond earlier, but quite frankly you had exhausted everything I could think of already. Well, at least you got it...but not before you chopped a hole in your trunk :lol:
PostPosted: Thu Aug 09, 2007 4:20 pm
Hey by the way, are you AWD guys using DSM AWD gas tanks in your mirages? I've got a AWD rear sub-frame just laying around and figured I'd make use of it by converting a mirage hatch, and I like the idea of using the stock tank.
PostPosted: Thu Aug 09, 2007 4:55 pm
GVR4. More flat, less tall
