It is currently Mon Apr 29, 2024 12:40 pm
 Post subject: up date on gt-35R hta
PostPosted: Thu Jul 17, 2008 3:18 am
so i have had the turbo for about 4 months now. went to the dyno about 2 months ago. put 467 hp on 28lbs aem average. torque was 347 approx. by the way that is the lowest torque numbers but highest hp I have ever put out. timming was from 20-22 degress before peak torque. about 24 degress after peak torque. aem knock volts no higher than 1.6 volts. so been to the track 2 times. 1st time with this set up at the track. I keep rolling the light. but I had to fix the air temp off set. car went down the track realy rich. so after I fixed it. it ran 128 mph. but still know 11's.
2nd time at the track started off the day with an 11.6 at a124 mph, busting 27 lbs. got boost right at 29 lbs started trapping 128 and 11.701.
raced my freinds fully built sleved civic. I lost but there was something on the track that made me lose traction. and his car blew up at the end of the track you can here it in the vidieo. he was boosting over 30. he was pegging 30 on s300 having boost controller problems.
I am still running on 6yr old stock motor with stock headgasket, stockhead studs and bottom end no internals. been putting out 400+hp for at least four years on this engine.
my freind didn't get my 11.6 video, or my 13.0 on street tires.
anyway here are some videos enjoy.
http://www.3rdgearvtec.net/Andys%20Vide ... slicks.wmv
http://www.3rdgearvtec.net/Andys%20Vide ... 0tires.wmv
http://www.3rdgearvtec.net/Andys%20Vide ... ntucky.wmv
http://www.3rdgearvtec.net/Andys%20Vide ... 20pass.wmv
http://www.3rdgearvtec.net/Andys%20Vide ... ss%202.wmv
PostPosted: Thu Jul 17, 2008 7:29 am
timing :wink:
Was this on pump gas? Impressive either way, congrats :drinkers: . That HTA option might not have been the best for a fwd street car (bye bye tires :twisted: ) I bet that your car is hella fun on the street.
PostPosted: Thu Jul 17, 2008 4:26 pm
yes it was on c16 with a 63ar housing. when I get e built motor I will change it to an 83. also about 2.25 exhaust down pipe.
PostPosted: Mon Aug 11, 2008 11:44 am
Get that damn downpipe fixed
 Post subject: specs
PostPosted: Thu Sep 18, 2008 3:00 pm
Can I get any specs on ur setup cams intake ect? I just would like to know You said stock head studs I thoguth on a 4g63 they are head bolts? :-?
92 Colt swap sold
91 Eagle talon gt4202 powerd stock block 26psi
97 Eagle talon way to many mods to list
