Here is our classes and also class rules. We only have 2 rule based classes one is street and one in pro. These are index classes with only one bracket class. Index racing means its heads up off a pro .400 tree and as long as you dont go faster then the time index and you beat the other car you advance. Its not bracket racing. No rules just balls to the walls racing.
Class information along with 07 schedule.
Street Division
Street Fighter $40 entrance fee
Bracket Racing - Standard Tree
12.000 - 19.999
Street Warrior 13.00 $40 entrance fee
Heads-up 13.00 Cap - Pro .400 Tree
Anything goes
Street Intimidator 12.50 $40 entrance fee
Heads-up 12.50 Cap - Pro .400 Tree
Anything goes
Street Heat $45 entrance fee
Heads-up 11.60 Cap - Pro .400 Tree
Anything goes
Street Avenger $60 entrance fee
Heads-up 10.50 Cap - Pro .400 Tree
Anything goes
Street Dominator $60 entrance fee
Heads-up - Pro .400 Tree
Street Dominator Rules
Engine
1. No aftermarket blocks allowed
2. Production Intake Manifolds Only (mass
produced) no welds on intakes for purpose of
modifying
3. 75 mm Throttle Body "max" for fuel
injected applications
4. Only original manufacture, generally
available heads, accepted by IMSM,
permitted.
5. Engine Plates not permitted
6. Any size bore or stroke permitted.
7. Solid engine mounts permitted.
8. One-off or custom made cylinder heads
prohibited.
9. OEM standard bolt pattern for head, intake
manifold and header exhaust pattern only.
10. All standard IHRA Rules must be
followed in accordance to ET?s.
Drivetrain
1. Power Glides not permitted unless came
from factory.
Suspension
1. Any suspension allowed.
Tires
1.28"x10.5" ET Drag Max
2. 28"x11.5" ET Street Max
3. No "W" tires
Forced Induction General
1. No Piping inside car for intercooler,
intercooler must be placed between front
bumper and firewall no exceptions.
2. Multi-staged forced supercharged induction
systems are prohibited.
3. Internal gear ratios may not be altered from
stock.
4. 3.5" Inlet pipe max
5. Allowed superchargers and turbos are
restricted to stock or PRO accepted
commercially available, standard mass
production style units. Internal of units
(gearing, impeller, drive train) etc. may not
be modified in any area. Pushrod-based
engines must use standard rotation (no reverse)
supercharger, with supercharger
inlet mounted rearward facing. Ford
4.6L/5.4L Modular-based engine may use
reverse rotation supercharger.
6. No modifications to the hood or any body
panels.
7. Nitrous oxide may not be used in
conjunction with any other power adder.
Superchargers
1. Approved superchargers by IMSM are as
follows Vortech V-2 SQ S Trim, Vortech V-1 S
Trim, Vortech YS Trim, ATI P-1SC, ATI P-
1SC-1, ATI P-1SC-2, ATI D-1, ATI D-1SC,
PAXTON NOVI 1200, PAXTON NOVI 2000
2. Serpentine belts only on blowers, no cogs.
Turbo Chargers
1. No forward facing turbo
2. 76 mm Max
Nitrous Oxide
1. Nitrous oxide entries are restricted to a
single stage nitrous plate.
2. Nitrous oxide entries restricted to two (2)
single 10 lb. nitrous bottle or one (1) 20 lb.
nitrous bottle.
3. Push systems prohibited.
4. The uses of agents other than nitrous
oxide as part of, or mixed in, the system are
prohibited.
5. If entry is entered as a non-nitrous entry,
all solenoids, lines, fittings, and bottles must
be removed prior to technical inspection and
any competition runs.
6. Nitrous system must be entirely contained
within intake manifold.
7. Limited to one nitrous nozzle, and one
nitrous orifice, per cylinder. Progressive
systems not permitted.
8. Nitrous purge system permitted, purge
must exit at the cowl area away from inlet
area of the hood or hood scoop. Purge tube
must exit via a straight tube a minimum
length 4 inches protruding from the cowl, and
may not be within 12 inches of the opening
of the hood. Plume or nail head at end of line
in prohibited.
Exhaust
1. Mufflers required
2. Any style exhaust permitted
Fuel System
1. Heating or cooling fuel by any means
prohibited.
2. Altered fuel tank or cell permitted. Must be
located in trunk or rear of vehicle.
3. Any injector size permitted.
Gasoline
1. Mixing of fuels is prohibited.
Oil System
1. External oil pumps prohibited.
2. Oil lines run outside engine block to feed
oil galleries prohibited.
3. Vacuum pump and/or evacuator system
(header, or otherwise) prohibited.
Body
1. Vehicle must retain original appearances
and profiles for year and make of body.
Original O.E.M. body shell (unibody structure
from firewall to taillight panel must be intact).
Only lightweight body panels permitted are
hood, bumpers, and trunk-lid/hatch/deck-lid.
Hood and/or trunk lid must be hinged or lift
off.
2. Stock, unaltered firewall required.
3. Windows must be operational.
4. Doors must be operational from outside
and inside.
5. Commercially available body kits
permitted.
6. No lift off front ends.
Electrical
1. Battery may be relocated.
2. Charging systems including stock
replacement alternator must be operative,
may be relocated.
3. Any form of aftermarket ignition permitted.
4. All optical sensors, delay boxes, stutter
boxes, etc. prohibited.
5. All systems must have on-board starter in
stock OEM locations.
Weights
Big Block n/a 470 ci max...........3,200lb
Small Block n/a Any ci...............2,800lb
Small Block Power Adder..........3,200lb
(Forced Induction Only)
Nitrous Injected.........................3,050lb
Miscellaneous
1. Vehicles may not be towed in or to staging
lanes. Vehicles may not be towed from the
return road.
2. Headlights and tail lights for year & make
of body used mandatory.
3. Must have functional horn.
All standard IHRA Rules must be followed in
accordance to ET?s.
All rules are subject to change
Pro Division
Pro X-Treme 8.60 $135 entrance fee
Heads-up 8.60 Cap - Pro .400 Tree
Anything goes
Pro Outlaw 7.50 $135 entrance fee
Heads-up 7.50 Cap - Pro .400 Tree
#3200 Min.
Anything goes
Pro Eliminator $100 entrance fee
Heads up Pro .400
Pro Eliminator Rules
Engine
1. No dry sumps
2. No EFI on big blocks.
3. Max C.I. 650.
4. Dual carbs add 50 lbs.
5. No power adder on big blocks.
6. Any intake allowed
Drivetrain
1. Any transmission acceptable.
Suspension
Wheels and Tires
1. Max tire size 14? on pavement.
2. No tire larger then 14"x33"
3. Any type of wheel permitted.
1. Multi-staged forced supercharged induction
5. Allowed superchargers and turbo are
panels.
Superchargers
Trim, Vortech V-1 T-Trim, Vortech V-27 YSTrim,
Vortech V-27 YSi-Trim, ATI P-1SC, ATI
P-1SC-1, ATI P-1SC-2, ATI D-1, ATI D-1SC,
ATI F-1, ATI D-1R, ATI F1R, PAXTON NOVI
1200, PAXTON NOVI 2000.
Turbo Chargers
2. 88 mm Max
Nitrous Oxide
single stage nitrous plate. Single stage
fogger systems acceptable.
10 lb. Nitrous bottle or one (1) 20 lb bottle.
prohibited.
in prohibited.
Frame and Suspension
1. All forms of stock and aftermarket
assembly?s permitted.
2. Sub frames on uni-bodied cars may be
joined under car.
3. Notching for rear end clearance permitted.
4. Rear and front tubs permitted.
Exhaust
Fuel System
prohibited. 2. Altered fuel tank or cell permitted. Must be
Gasoline
1: All cars must run on gas. Any octane, lead
or unleaded racing fuel permitted.
2: No alcohol
3: No nitro
Oil System
1. External oil pumps permitted.
Body
off.
and inside.
permitted.
Electrical
may be relocated.
Weights
Big Block n/a 650 ci max..............3,050lb
Small Block n/a Any ci..................2,800lb
Small Block Power Adder...........3,200lb
Nitrous Injected...........................3,050lb
Miscellaneous
lanes.
2. Vehicles may not be towed from the return
road.
3. Vehicles must be driven to scale, maybe
towed from scale.
4. Headlights and tail lights for year & make
of body used mandatory. Head lights & tail
lights.
5. No dragsters.
accordance to ET?s.
All rules are subject to change.
All cars are to meet safety requirements as required by track.
IMSM Tech inspection is final
Rules and regulation subject to change.
IMSM 2007 Schedule
April 22 Byron Dragway, Byron IL---- IMSM Opening Day
May 12 Great Lakes Dragaway, Union Grove WI (Racing Under the Lights)
June 10 US41 International Dragway, Morocco IN
June 30 Cordova Dragway Park, Cordova IL (Racing Under the Lights)
July 8 Byron Dragway, Byron IL
July 29 Great Lakes Dragaway, Union Grove WI
Aug 26 US41 International Dragway, Morocco IN
Sept 30 Byron Dragway, Byron IL ---- IMSM FINALS
Class pay outs are so far based on car count at this point. We dont have enough sponsors to help out with a cash payout but the ones we do have help out in any way they can. So the more cars the more money you will win at the end of a event.
All class payouts will follow the same formula and breakout as those posted in Pro Eliminator. Only the dollar per car will change. All classes will have the same breakdown procedure for odd number fields. In no case will there be a payout lower than semi final loser. The dollar per car for each class are as follows.
SF = $10
SI = $15
SH = $15
SA = $30
SD = $30
PE = $70
PX = $100
PO = $100
Street Compact = $10
Formula for 8+ cars:
#of cars X Class dollar p/car = TTL purse
Winner = TTL purse X .50
R/U = TTL purse X .30
Semi Loser = TTL purse X .10
Formula for less than 8 cars:
#of cars X class dollar p/car = Total Purse
Winner = TTL Purse X .60
R/U = TTL Purse X .40
As you can see the more cars in each class the higher the payouts will be so lets see some full fields of cars!!!
We are working on the rules for the FWD cars to run slicks in Street Dominator if they choose to run that class
