July Ride of the Month! http://www.4g61t.org/forum/viewtopic.php?f=43&t=14508 |
Author: | akdriverjd [ Tue Jul 12, 2005 10:27 pm ] |
Post subject: | July Ride of the Month! |
Well ladies (not so much) and gents, I've got a real treat for you. You may recall this epic post right HERE. If you read that, you learned about two very unique CSMs. One is bright yellow, clean as hell, and fast as balls. The other one is an AWD, 400hp beast of a sedan. It just so happens that that bright yellow banana colored one is going to be gracing our pages today... Well, I could write something up, but the fact is that Paul is pretty eloquent himself...so I'll let him do some of the explaining for this month. ![]() Quote: Basic story on the car: I have been into DSM's (edit by jd: ![]() So now I had a pile of dirty parts, and no car. I still began the painstaking task of cleaning everything up, bead blasting and polishing the aluminum, and collecting the other essentials for a swap. I was looking hard for a semi-clean base model CSM to swap into, and finally ended up buying the car off the forsale forum here on 61T in the spring of 03' with 118,000mi on the odometer. The car itself is a 91 Colt GL, yellow is the factory color, and it came with a 12V 4G15, 5 speed, PS, and AC. The previous owner had installed the blue 89 Mirage turbo interior and steering column before I got it, along with some extra-pimp Ultra brand 5 spoke wheels. I drove it for about 10,000mi with the 4G15, parked it for the winter of 2003/04', and pulled the drivetrain for a little renovation. I had the 4G63 ready to run with a few relatively mild things done to it. Initially the car was put together with a 14B, 2G exhaust mani, no balance shafts, 450's, 90 ECU, Centerforce clutch, Wallbro 255lph pump, -6AN fuel system, and lots of OE Mits parts to ensure that I could keep it on the road and drivable. I freshened up and installed the engine in my gravel floor garage at school with the help of a couple loyal DSM buddies and fabbed a full 2.5" stainless exhaust from turbo to tip. Though the car wasn't yet intercooled, it still managed to pull quite well at 8psi. The summer of 04' had some changes in store for the Colt. It was proving to be a great daily driver, and miraculously had seen over 10,000mi of swapped action without missing a beat. I bought a MAF translator, Spearco 17x7x3.5 intercooler, and some 650cc FIC injectors to help liven things up a bit. I fabbed my own 304 stainless intercooler piping to match the setup, and turned the boost up to realize what the car was really all about! At 17psi, I managed to eek out a 13.1@110 after many passes on slicks and 110 octane with the 14B. I drove it like this through the rest of the season, and once again, the mod bug bit again... Fast forward to 2005. I was having fun in the car, but wanted to really make it into a true street terror. I bought a whole list of bolt-on mods for this year, and I still am having a blast commuting it to work every single day, rain or shine. The chassis and engine both have around 167,000 miles on them at the time of writing, and I have bested a 12.73@114 so far this year with 3 passes on the new setup. The worn old junkyard engine still managed to lay down 320whp and 300lb-ft of torque in street trim (21psi/pumpgas) with no indication of an unhealthy demise in the immediate future. I built the car for my own personal enjoyment, assembled it with my own two hands, and I have every intention of keeping it streetable and fun. Besides, what good is it if you cant drive it!? Modifications Engine: 90 4G63 6 bolt shortblock, bal. shafts removed ARP headstuds w/OE gasket Stock rebuilt head and 1G intake HKS 272/272 cams Fidanza adjustable cam gears Evo 3 Exhaust manifold (ported) Evo 3 16G turbo from MHI (ported) AMS braided turbo oil feed line FP flexible oil return line Magnecore 10mm plug wires Setrab oil cooler w/-8AN lines to 90 oil housing Custom 2.5" 304SS O2 eliminator setup w/1-3/4" open dump WG Custom 2.5" 304SS exhaust system w/Summit stainless muffler Interior/Fuel/Air/Electronics: Wallbro 255lph HP pump, 10ga rewire Aeroquip -6AN fuel line w/Earls -6AN billet filter DSMotorsport -6AN fuel rail adapter Full Throttle Speed adjustable FPR w/Carbon fiber 60 PSI gauge Fuel Injector Clinic 650cc Injectors HKS Vein Pressure Converter (VPC), Buschur 660 chip HKS Graphic Control Computer (GCC) HKS Electronic Valve Controller (EVC) 90 DSM FWD ECU, non-Eprom AEM 2" UEGO Wideband gauge, sensor in downpipe for leaded fuel use Autometer 2" Z-series 30-0-30 Boost gauge Autometer 2" Z-series 0-100psi electric Oil press gauge Custom billet aluminum single-DIN 3 gauge panel Spearco 17x7x3.5" FMIC Custom 304SS Intercooler piping, 2" J-pipe, 2.5" on everything else Derale 12" Slimline cooling fan HKS Super Sequential BOV w/custom stainless flange 20% Tint on all windows except the doors (fricken PoPo!) Sony CD player with Infinity Kappa speakers all around Blue Mirage turbo Interior/turbo cluster/turbo column and wheel Oddysey PC680 13lb battery to replace the humongoid 40lb stocker Driveline/Suspension: KM210 transmission (just freshened up) Stock mirage turbo axles (redone by RAXLES) Fidanza 8# aluminum flywheel ACT 2600PP w/street disc 91 GVR4 rims w/Yokohama AVS ES100 street tires 195/50/15 92 GVR4 rims w/M&H Racemaster slicks 23x7.5x15 KYB GR2 Stock replacement struts w/stock 1.5L springs (eek!) Mirage Turbo front brakes w/Brembo rotors/Metal Masters pads RRE Stainless Braided brake lines 2G front strut bar w/custom brackets Shortened stock shifter (3"), custom turned delrin shifter base bushings and custom brass shifter linkage bushings. Still to finish up... Add an auxiliary cooling fan for those 100F days Turbo brake swap on the rear (have most of the parts) Suspension (probably DSS coilovers) Ported head/titanium retainers/HKS springs/SS Valves Built bottom end - ross/eagle combo ![]() The uber 1337 4g15 power plant! ![]() Donor ![]() GVR-4 Rims ![]() 4g63 Engine ![]() The cleanest engine bay EVER. Period. ![]() The fatty front mount... ![]() Pretty much the coolest shot ever. Well that's it for this month, hope you enjoyed yourself, be sure to tune in next month...does locked welded front differential + 500+whp + 2,000lbs mean anything to you? ![]() -akdriverjd |
Author: | TheDon [ Tue Jul 12, 2005 10:58 pm ] |
Post subject: | |
its so beutiful...gives me hope for my lil colt..excellent car |
Author: | TheDon [ Tue Jul 12, 2005 11:02 pm ] |
Post subject: | |
also..how did ya get that engine area sooo fresh and clean..just took everything out when you did the swap and presure washed? and with the engine in the forrest of vacume lines and sensor wires is not their..i must know how you did that |
Author: | 89Mirageman [ Wed Jul 13, 2005 12:04 am ] |
Post subject: | |
I've said it before and now I'm saying it again. That is one clean, bad@ss car! Great Job! |
Author: | The Ethereal [ Wed Jul 13, 2005 6:35 am ] |
Post subject: | |
OMG! ![]() ![]() |
Author: | netninja2001 [ Wed Jul 13, 2005 1:34 pm ] |
Post subject: | |
he get's it so clean by hand polishing EVERYTHING. the man LOVES his hand polishing. lol! even at last years shootout i remember him standing there with a bottle of windex and a roll of paper towels. ![]() |
Author: | coltanostra [ Sat Aug 13, 2005 11:35 am ] |
Post subject: | |
Really well done!Very clean and hot Ride,and i like the black wheels on the upper pic. ![]() |
