| 4G63 rat rod dyno=800.3hp 556tq http://www.4g61t.org/forum/viewtopic.php?f=42&t=38193 |
| Author: | biglady112 [ Wed Oct 16, 2013 12:54 am ] |
| Post subject: | 4G63 rat rod dyno=800.3hp 556tq |
2.0 4G63 9.2:1 custom Arias pistons Pauter connecting rods TH400 transmission Holset HX52 44psi Dsmlink 1150cc primaries 6-1600cc secondaries Magnafuel mechanical fuel pump GSC S3 cams Bone stock cylinder head(no porting) 1G non-turbo throttle body Stock 1G intake manifold, no porting L19's@110lb/ft Mitsubishi four layer head gasket(no orings) BR10ES pulgs at .020" gap Accel wires Accel Ford coil Stock ignitor 800hp 556tq corrected 640hp 445tq uncorrected at 6100ft The videos are very long as I don't know how to edit nor did I take the videos. One shows the truck from the front at 41psi, the other is the 44psi pull. https://www.youtube.com/watch?v=77KObjt ... ata_player https://www.youtube.com/watch?v=CovWhqQ ... ata_player |
| Author: | slowdsm [ Wed Oct 16, 2013 1:15 am ] |
| Post subject: | Re: 4G63 rat rod dyno=800.3hp 556tq |
very nice man.. now to get some vids of u driving it. Steve |
| Author: | Spoolin [ Wed Oct 16, 2013 8:31 am ] |
Finally gave up on the 1.6. How's the head gasket holding up? Congrats on making some big power! |
| Author: | biglady112 [ Wed Oct 16, 2013 8:48 am ] |
The 1.6 seized on the dyno a few months ago after three hours. I would have kept it, but there was no point in trying to build one. It now lives in Florida and will go to good use. |
| Author: | Mechacode [ Wed Oct 16, 2013 10:18 pm ] |
Spiffy. What's with the thing between the windshield glass? |
| Author: | biglady112 [ Wed Oct 16, 2013 10:21 pm ] |
Shifter tunnel. 3ft long shifter in there. |
| Author: | boostfreak [ Fri Oct 18, 2013 3:20 pm ] |
Suprised the tired held! Good work. With that king of power curve, it seem kind of geared twards drag-are your going to drag race the car? Seems sketchy Also do you activate the Meth fueling with Link? |
| Author: | biglady112 [ Fri Oct 18, 2013 3:43 pm ] |
It has 3.31:1 gears in the rear. And the th400 will allow 145ish in second and 235ish in third with this tall of a tire. Right now the thing will only be used for joy rides. If anything it may have a future in standing mile events. All ten injectors currently spray E85. And dsmlink controls them all with the help of an AEM 10 channel driver box. |
| Author: | grndsm [ Sat Oct 19, 2013 9:49 am ] |
How high did you rev it? This is very impressive on a stock intake! |
| Author: | biglady112 [ Sat Oct 19, 2013 10:35 am ] |
9000rpm. It is not efficient enough nor a big enough turbo to need to go further. |
| Author: | Mechacode [ Sat Oct 26, 2013 8:37 pm ] |
Quote: Shifter tunnel. 3ft long shifter in there.
Wat. |
| Author: | biglady112 [ Tue Oct 29, 2013 7:37 am ] |
Here is two shorter more to the point videos. https://www.youtube.com/watch?v=WjBNhdl ... ata_player https://www.youtube.com/watch?v=g2DzveG ... ata_player |
