It is currently Sun Nov 02, 2025 9:39 am
to put a 4g63 in my ghia or not
leave the air cooled flat 4 14%  14%  [ 1 ]
or swap a 4g63t in 86%  86%  [ 6 ]
Total votes: 7
PostPosted: Thu Nov 20, 2008 8:40 pm
they make an adapter to go from 4g63 to vw trans axle
http://www.kennedyeng.com/vw_por.htm
its at the bottom
PostPosted: Thu Nov 20, 2008 8:46 pm
That company makes adapters for anything you could ever imagine. If they don't, they will make a custom one for you and then they will begin selling that.
PostPosted: Thu Nov 20, 2008 9:06 pm
Honestly, I don't like either option in your poll. I find a 4g63 a poor choice to replace a vw air cooled boxer. Iron blocked engine vs aluminum blocked engine... The best choice would probably be a Subaru EJ series engine. Next best choice would be a Mazda KL series V6.
I plan on using one of those engines to replace the wasserboxer in the Vanagon soon.
PostPosted: Thu Nov 20, 2008 9:51 pm
well they run 2.0 8 valve vw motors in the race cars all the time. and have you ever picked up an ej 20 or ej25 the way as much as a 4g63. i was just thinkingit would be cool to have a 500hp 4g63 in a ghia but ill will probably stay aircooled.
also the wasserboxer case is a great drag case if you machine the water jackets off and put air cooled jugs in it they take alot of abbuse.
PostPosted: Thu Nov 20, 2008 10:50 pm
The benefit of the flat or v engines is the lower center of gravity. I'm going to have to go that way to get everything fitted nicely under the engine cover. I'm also doing it to replace the overheated/broken engine. Big benefit is cheaper and easier to find parts. I can find subarus and mazda engines all day long at the pick-n-pull. Try finding a wasserboxer.
PostPosted: Fri Nov 21, 2008 12:34 am
I think it would be pretty bad ass to have a 4g in a ghia. a friend of mine and i were thinking of doing the same to his sandrail. And if you did eventualy decide to get the adapter my coworker's room mate works at kennedy engineering Products (its about 15min away from my apartment) so let me know :D
PostPosted: Sun Nov 23, 2008 4:17 pm
PostPosted: Sun Nov 23, 2008 9:48 pm
Plebani says it all ..... :twisted:
PostPosted: Sun Nov 30, 2008 10:42 am
the JDM KL-ZE is a sweet motor, but why bother with that mazda motor when you have the FE-DOHC? :supz:
PostPosted: Sun Nov 30, 2008 4:47 pm
The US didnt get the FE-DOHC. We got the FS-DOHC though. I have one laying in my backyard... but KLDEs are a dime a dozen. You can get them in a ton of Mazda vehicles, cheap parts, aluminum block, lower center of gravity than an inline engine, and higher displacement. The easiest to get of the aluminum block V6s.
PostPosted: Sun Nov 30, 2008 7:15 pm
the FS is a pile pretty much though. i actually have a built 626gt with a fe-dohc in it. great little beast. currently i own 4 mazda's along with my turbo colt, and a beater 92 explorer. (im converting it to a mazda navajo) lol.
