| Spring '08 build pics (updated 11/15) http://www.4g61t.org/forum/viewtopic.php?f=42&t=25229 |
Page 1 of 3 |
| Author: | 123abc [ Sun May 25, 2008 8:55 am ] |
| Post subject: | |
Nice man, looking clean. |
| Author: | colt200 [ Sun May 25, 2008 10:56 am ] |
| Post subject: | |
Click here to watch new-head-39 Can anybody explain this video... Click here to watch smoking-vent - it seems to be smoking out of the valve cover vent. I am not sure why, I have never heard of this before. Every other time when I put the engine back together I always had that line going back into the intake piping so I did not notice it before. I think it is smoking a little bit more than I would like. |
| Author: | lostkause17 [ Sun May 25, 2008 11:06 am ] |
| Post subject: | |
ur rings are bad. Do a compression test on the motor. That is whats called blow-by. I can almost guarantee that one of the rings is bad I have had a couple motors do that. Usually the number 1 or 3 cylinders |
| Author: | Incoltnito [ Sun May 25, 2008 11:12 am ] |
| Post subject: | |
^^^ What he said. I was going to mention checking your PCV valve to make sure it's not plugged. |
| Author: | lostkause17 [ Sun May 25, 2008 11:15 am ] |
| Post subject: | |
thats to much smoke for a pcv valve. But you could always try it |
| Author: | 89coltgt [ Sun May 25, 2008 12:00 pm ] |
| Post subject: | |
If his rings were that bad, I would think he would have alot of smoke coming out of the exhaust. Either way,perform a compression test on the engine. |
| Author: | Incoltnito [ Sun May 25, 2008 12:48 pm ] |
| Post subject: | |
Definitely a compression test is in order. I mentioned the PCV because his breather is supposed to "breath in" and gets drawn into the intake manifold via the PCV valve. If it's plugged, then the gas has nowhere else to go but back through his breather. But then again.....that is a wee bit more smoke than usual. |
| Author: | CaptainTonus [ Sun May 25, 2008 3:37 pm ] |
| Post subject: | |
Either your engine is built to extremely loose tolerances, or there is a bad ring somewhere. Does it always smoke that much? |
| Author: | colt200 [ Sun May 25, 2008 4:36 pm ] |
| Post subject: | |
It never smoked out the valve cover before. I rebuilt the engine almost 3 years ago now I think. Its already bored .020 over so I think I will dig the spare block out of the shed and order up some better internal parts. |
| Author: | biggspeed [ Wed Jun 25, 2008 8:28 am ] |
| Post subject: | WoW |
Well that would explain the blow by! Not the sort of explanation one would like to see however. So whats the plan now then, is it rebuild time with the spare block? |
| Author: | colt200 [ Wed Jun 25, 2008 9:26 am ] |
| Post subject: | |
I am rebuilding the block that came out of there. The head already is done. Ported, oversized valves, 272 cams, gears and all the other good stuff. The block is going .040 over and forged parts. Getting everything balanced and hopefully with in the next year a bigger turbo... I am not sure how much the 20G can do. |
| Author: | 92 gsr-4 [ Sat Jun 28, 2008 1:46 am ] |
| Post subject: | |
Very Nice |
| Page 1 of 3 | All times are UTC-05:00 |
