The 3065 is a bolt-on turbo. Bolt-on turbos have limitations. The 6262 is significantly larger both on the compressor and turbine sides, and it has a billet compressor wheel making it much more lightweight and easier to spool.
Ah, thanks man. I haven't been on here in forever let alone been able to get on and do any kind of research due to work, lol.
I knew the billet wheel would definitely make a huge difference. I also knew that the 3065 is ball bearing, where the 6262 is a journal bearing. I was just unsure in the differences of having that billet wheel with the journal bearings.
So is having the billet wheel with the journal bearing will be comparable to the 3065's ball bearings?
