It is currently Fri Mar 29, 2024 2:32 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Tue Feb 16, 2010 9:01 pm
Well something has come up, and it would really help me to go ahead and sell this thing. As much as I know I'm going to regret it, it's time...
Here are the Cars specs.
Rear axle with 4-link set-up
Driveshaft (custom built by Cleveland custom clutch)
1 set of wheels and tires. 15" rims and 15" drag radials (2 slightly used, 2 brand new)
1 Kirkey drag seat with cover
2 Kirkey seat mounting set-ups
2 Cam lock 5 point harnesses
Sirroco alum. Rad.
GVR4 front knuckles
Colt GT specific axles. One brand new and other only has a few passes on it.
Complete 10 point roll cage
New Tie rods at beging of season
New sway bar links and bushings at begining of season
KYB GR2 struts on all 4 corners with coil-overs
Build pictures of when Craig built it:
http://www.4g61t.org/forum/viewtopic.php?f=3&t=23191
or
http://s106.photobucket.com/albums/m247 ... ?start=100
Video's of the car
http://www.youtube.com/user/cataplt
I've installed a black hood on the car, and removed the carpet for cleaning. I installed a stock c53a steering column as well. I can install the OEM c53a front brakes, or I can throw the gvr4 front hubs on it. I'll have to get rotors and such for it if I do... The upper core support has been replaced, but its only screwed down, I can weld it if needed.
Price is, $2700 negotiable. Thanks
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Feb 16, 2010 9:48 pm
Whaaaaat.
PostPosted: Tue Feb 16, 2010 11:18 pm
what size tires are on that thing ?
scot
PostPosted: Tue Feb 16, 2010 11:33 pm
Are the mounts and crossmember included? What about wiring harness? Please send me pics of the car as it sits with everything included in the sale. spoolinawd@gmail.com
Would you consider trade+cash for my caged fwd roller. My car is complete but I will pull my motor and trans out and trade rollers plus cash money. Or leave the trans and just keep my engine and turbo setup. My car has a custom cage, gvr4 knuckels and big brakes up front, dsm dash, dual 255s in tank with -8feed and -6 return.
Thanks,
Bryan
PostPosted: Wed Feb 17, 2010 12:31 am
wish i had a little bit more money to buy this.
PostPosted: Wed Feb 17, 2010 10:22 am
The car will incude all engine and transmission mounts, along with an original turbo colt wiring harness. I have a very serious inquiry about it already. If things fall through with it, I will go to the next in line. I'm not really looking for trades at this point, but if things open up I will let everyone know. Thanks!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Feb 17, 2010 11:00 am
lord someone buy this thing and stick an engine back in it. i seen it run at the shootout and seen it when john had it. i love it. i wish i was not a broke ass.
Red 90 talon AWD. evoIII, 20-25psi, 880cc, chip, maft, 272's.
Red 92 eagle summit 12v.
PostPosted: Wed Feb 17, 2010 3:19 pm
Love this car, hope is goes to another good owner.
PostPosted: Wed Feb 17, 2010 8:54 pm
the front wheel bearings in the stock GT hubs are also brand new.
Good luck Nate!
PostPosted: Thu Feb 18, 2010 10:16 am
Damn if I only had a few extra hundred bucks laying around.
If this is around in like a month I will be all over it.
Goodluck with the sale.
PostPosted: Wed Feb 24, 2010 8:03 pm
Pending...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu Mar 04, 2010 3:08 pm
Thanks for all the pm's but the car is sold. Thanks
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
