It's that time again. I'm parting out a 90 tsi awd. If you need pics of anything specific, just ask and I will get them for you:
-6 bolt block/ crank
-6 bolt rods/ pistons
-6 bolt head minus springs/ cams (I can include stock springs for free)
-awd tranny
-22 spline t-case
-driveshaft
-3 bolt read
-HKS 272 int/ exh cams
-HKS valve springs
-prothane motor mounts already installed in mounts
-Front ONLY KYB struts
-used energy suspension bushings
-3" turbo back exhaust w/ meghan racing downpipe
HKS Racing 3 1/4in. to 4 1/2in. out muffler
highflow 3 inch cat
-7cm2 ported exhaust manifold
-6 bolt arp head studs, used
-short throw shifter
-used clutch, recently new
-6 bolt flywheel awd
-recently replaced slave/ master cylinder
-mls hg
-ss exhaust studs
-Mitsubishi vc with ss bolts
-safc 1
-560cc injectors
-walbro 255
-aeromotive fp reg w/ ss lines
-greddy profec b
-greddy tt
-autometer phantom boost gauge
-autometer phantom oil pressure
-sunpro air/fuel gauge
-eprom ecu
-greddy catch can
-magnecore 10mm wires
-FMIC w/ all piping
-greddy catch-can
-2g mas
-radiator w/ fans
-cas
-coilpack
-tb w/ all sensors
-front axles
-brakes
-ps pump w/ lines
-starter
-alternator
-stock awd springs
-ac/ all lines
-interior items
-misc exterior items
-wiring harness
If you need anything you don't see, ask. This is just a basic rundown of what is available
