Up for sale is a 92 Laser 6 bolt 4 bolt from the factory with 105K miles. Used it as a daily driver with no mods until the clutch started to wear. It now has an ACT 2100 and RRE flywheel. Previous owner claimed to have replaced the timing belt around 95K. Other then the clutch, I replaced the tie rod ends, carrier bearings, and valve cover (original was cracked).
The car is Black and the paint isn't bad. It has a couple chips on the hood and the piece that surrounds the windshild wipers on the cowl is rusted. Also by the rear passenger side window part of the trim is loose. The interior is pretty nice besides the roof liner which is falling down. The previous owner installed a pwr/eco switch that acts as an anti theft system. The car won't start when its pressed.
I used it to get back and forth to work but now I just don't have the room for it. $3500 obo
More pics here
http://s198.photobucket.com/albums/aa47 ... aser%20RS/
