It is currently Sun Nov 02, 2025 4:46 am
 Post subject: I feel stupid
PostPosted: Thu Sep 29, 2011 2:08 pm
I just traded my green cup factory turbo drivers axle the wasn't leaking, it only had weather checked boots, for a skinny Carquest reman. I feel like a dumbass and feel dirty. Lol
 Post subject: Re: I feel stupid
PostPosted: Thu Sep 29, 2011 3:53 pm
that would be the incorrect parts then sir. have them order you the correct part.
4g61t.com
PostPosted: Thu Sep 29, 2011 4:05 pm
From all the info here on this forum, that's what you get these days if you can get one at all. Its not a non turbo axle, its the correct knuckles, splines, length etc, just a smaller diameter shaft. I've read every axle thread numerous times now.
I figure if I want big axles I can just use awd dsm axles since I have Expo hubs/spindles already.
PostPosted: Thu Sep 29, 2011 6:54 pm
Sorry to go off topic. How was the caster/camber on the car with the expo spindles? I have them and the car isn't even drivable
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Sep 29, 2011 7:13 pm
Its still torn apart. I'm gathering all new parts before I put it back together. I'm not worried as I have camber plates andalso extra caster bushings from Super Pro. More caster is better for high speed anyway.
PostPosted: Thu Sep 29, 2011 9:10 pm
Elantra lca's. Thats the ticket to dsm axles in our cars, in conjunction with either the expo or dsm spindles!
PostPosted: Thu Sep 29, 2011 9:14 pm
The center shaft would require removal of the ends/cups but you can swap them out, or trade the new parts onto them. Messy and yes you have to regoop, and seal the boots, but then you get the save the inner segments. Just a thought, don't be too hard on yourself, as the aftermarket is a stress to deal with anyways.
PostPosted: Fri Sep 30, 2011 1:47 am
I would tell them its the wrong part. also in some catalogs it's for an 88'. Why roll around with a weaker axle that doesn't quite fit right. Numerous people on the board were in the same position you were, all of them took them back. Don't be a pansy :D
4g61t.com
PostPosted: Fri Sep 30, 2011 11:56 am
Well, it seemed to me that several people here said that's what they used and were ok with it. It sounds like very few got "lucky" and got a thick axle, most got the skinny one of proper legnth and a few kept getting long axles, all from the same part #. I need the car back together and can't wait for months to try and keep ordering the same part over and over.
To be honest this axle has turned into such a pain in the ass for me that I'm almost tempted to try awd dsm axles and see if they fit, then if they don't get Elantra control arms. I already bought Super Pro bushings for my stock lcas but whatever. At this point money is not an object, getting my car back together is.
PostPosted: Fri Sep 30, 2011 10:26 pm
The OEM passenger axle measures 23.4mm. The OEM driver axle is 27.3mm -28mm in spots, it varies. The Carquest reman axle is 23.4mm just like the OEM passenger side. I'm gonna use it since its no smaller than the OEM passenger side.
PostPosted: Mon Oct 03, 2011 11:05 pm
Okay, no more beating a dead horse :horse:
4g61t.com
