It is currently Fri Oct 31, 2025 4:37 pm
PostPosted: Tue Sep 27, 2011 10:58 am
I wanted to thank everyone for your help. I finally accomplished a 4G37 Turbo. There has been a few others however no evidence of it running or boosting. I hoe you enjoy my success as I couldn't of done it without info and help from this forum!
If you want to view my build thread it can be found here....
http://www.dsmtalk.com/forums/showthread.php?t=227935
Here are the videos I was trying to take while driving. I since have fixed the stalling out issue as I have had several leaks in the couplers.
http://s648.photobucket.com/albums/uu20 ... D00004.mp4
http://s648.photobucket.com/albums/uu20 ... D00005.mp4
And here are some pics at a local MOPAR show I participated in.
I had to hybrid the turbo with the 9b Colt to a 13g from a DSM so I can adapt the J-pipe to the FMIC setup. I still have some issues to address like a leaking intercooler, wideband, FPR and install some bigger injectors as well as BPR7es plugs. Thank you everyone for you help!
1994 Laser R/T 4G37 Turbo
1992 GTA Trans Am 5th Anniv.
1989 Silverado
1984 Maserati Biturbo 2.5TT
1980 Turbo Trans Am
1976 Trans Am 455
PostPosted: Tue Sep 27, 2011 9:42 pm
Hey man, that is awesome that you got it running and better yet, looking so clean!
Keep it up, that is some major work right there. :rock:
PostPosted: Wed Sep 28, 2011 4:18 pm
That is why I wanted to thank this site, because alot of the information wasn't available anywhere else. The CSM's and DSM's should be more united and hopefully this is a foot in the right direction. We can both learn from eachother as I did in this case. Thanks all again for helping me with this!
I am going to stay a member of the forum and try to be a contributing member when possible :)
There has been a few whom said to have turbo charged a 4G37, however with no evident running proff of it as well as the creators disapear right after hand it was hard to believe. Also for the fact the loss of several years between the last attempt.
1989 Silverado
1980 Turbo Trans Am
1976 Trans Am 455
