http://www.4g61t.org/forum/
Rockauto black top cas closeout? $32
http://www.4g61t.org/forum/viewtopic.php?f=3&t=35098
Page 1 of 1
Author:  89Mirageman [ Wed Jul 27, 2011 10:05 pm ]
Post subject:  Rockauto black top cas closeout? $32
Rockauto has 9 black top cas's on clearance for $32 each. I just ordered mine a few minutes ago. I'm hoping the pic on their site is the correct one, if not I'll just send it back or something. Order at your own risk!
Just go to their site and look up a 92 Galant VR-4 and search for crankshaft sensor.
Author:  Coltsfan [ Thu Jul 28, 2011 12:17 am ]
Post subject:  Re: Rockauto black top cas closeout? $32
This one?
STANDARD MOTOR PRODUCTS Part # PC205 {#MD144529, MD184529} Intermotor
[Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] DOHC; $219.79
It went up. :(
Author:  89Mirageman [ Thu Jul 28, 2011 9:42 am ]
Nope, there was another one made by Delphi. I checked the site again about an hour after I posted this and they were all gone. I posted it up on the Galant board as well, I didn't think they would last too long.
Author:  Coltsfan [ Thu Jul 28, 2011 4:01 pm ]
I always miss the awesome deals.
Author:  j2dapo [ Thu Jul 28, 2011 4:58 pm ]
Whats the difference? I think the black one has a magnetic pickup where as the older ones are optical.
Author:  Mechacode [ Thu Jul 28, 2011 5:34 pm ]
The signal is a little better, more precise.
Author:  LILEVO [ Fri Jul 29, 2011 3:34 pm ]
And if you go with a triggerdisc then you must use the green style CAS
Author:  MR HYDE [ Mon Aug 01, 2011 11:58 am ]
It's the other way around. Black top is optical which is "supposed" to be better.
Author:  j2dapo [ Mon Aug 01, 2011 12:23 pm ]
Really, I think Jason just confirmed that's not the case.
Author:  pma1123 [ Fri Aug 05, 2011 10:32 am ]
jdapo, I've had both of them open, the green top relies on stamped holes in the rotor for the optical pickup, the blacktop has 4 metal fingers that pass by magnetic hall effect sensors.
So really its the other way around from the other way around...
8)
Author:  MR HYDE [ Sun Aug 07, 2011 4:55 am ]
lmao!!!!
So I'm mstuck.. which way is it
https://www.phpbb.com/
