one of my local guys here has an auto awd dsm with a fp3575 on a stock converter and a 50 shot.
even with nitrous he couldn't get it to stall above 2600 rpm, even with anti lag. (not anti lag and n20 together, thats a bomb waiting to happen)
he backed out about 3 degrees of timing at 2600 to 3300 rpm and with the 50 shot was able to spool boost in and take it to 3800 rpm on stock converter, and actually launch the car at near full boost.
(he used to run 14's at 127 mph, but hasn't been back to track since)
you mentioned you had it setup for nitrous to take timing out at full throttle, was that selection turned off in dsmlink or was just the nitrous turned off ? a few people on link have found that by taking some timing out off boost they were able to spool the turbo faster, (as opposed to the adding timing, run leaner thought process from years past) as it leaves more heat in the exhaust to spool turbo easier.
I have it setup to turn on the bottle and back off timing every time I go full throttle, but the arming switch needs to to be on to actually have the solenoids turn on.
Hea paul, from what I have understood over the years, the ecu is in full closed loop anything over 92% throttle. That was coming from Tom and Dave. So the 95-99% should not make a difference over say 100%.
Are you using antilag at all when you stall? I know that is common practice among some auto guys. I know Kiggly has been doing it for some time now.
I think you guys are on the right track though. The converter is finally loosening up or failing(lets hope not) and the car can get on the converter like it should have been all along.
Is it possible to spray it to flash it up on the converter and then turn the nitrous off on the line? And then maybe turn it back on down the track some where? I am not sure dsmlink can do this, but maybe just set it up with a simple switch. These ideas are more for the 50 trim, as a 16g should stall up with just dsmlink alone.
Maybe you can share with us what you have experimented with. A few extra brains and eyes in the mix never hurt.
last time we did try the anti lag and what i have seen other people deal with is that antilag does not work that well with auto's. from what i remember they need they need the tq to get it up on the converter and when you use the antilag it takes away tq. i could be wrong but that is why it does not work that well on the auto's without a crazy loose tq converter.
I have thought about using it to flash the converter as well but was going to try that once i get the 50 trim on and go from there. I figure if i can get it out of the hole with a 1.6 60 ' (I can dream cant I) that would be an easy 10.
