It is currently Mon Nov 03, 2025 2:36 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Mon Sep 19, 2005 10:02 pm
This car belongs to a good friend of mine...and its probably the sickest daily driven street legal car I've ever seen. It has run 10.40's@132 on street tires (the ones in these pictures) with 93 octane/methanol. It currently has around 550whp, tilton carbon clutch, gt35r tuned by brad brooks with aem. As you can see by the pictures, the car doesn't have a cage which means its impossible to run more than two passes with the car before Jerry (the owner) is asked to leave the track. At this time he is currently not allowed back at Bradenton Speedway until he has a 10 second approved cage.
The car is lower in the front because of two things. One, the springs in the front have sagged a little below where the car once sat. Second, the car squats so dramatically (it weighs 2500lbs) that the exhaust drags on the ground for the first 50ft upon launching.
The motor is a built 2.4L stroker setup, cams, cyclone intake, custom alky control based methanol injection setup which allows for 32-34psi with 93 octane, Jerry Built transmission, Tilton carbon/carbon clutch (costs about 3,000 dollars), 4 spider center differential, custom fmic, and a plethora of custom parts which would take too long to describe. Jerry fabricated a 4bolt rear end into the car which makes it all wheel drive (for those unfamiliar with dsm's) and is one of the only mirage's i've ever seen with this conversion.
I have driven this car (i'm one of the few who have been lucky enough) and it absolutely flies. The difference between most 10 second cars and this 10 second car is that it runs 10's on the street and it's setup is unchanged at the track. Meaning, the tires are the same, the tire pressure is the same, the boost/fuel/alky setup is the same along with everything else remaining unchanged when taken to the track. All 4 tires break loose under 80mph as soon as full boost is reached which is nearly instantaneous with the current setup. The cyclone intake manifold is restrictive up top (probably preventing 600whp) but spools the gt35r almost immediately.
Overall, the car is absolutely insane and i consider myself fortunate to have ridden in and driven the car.
I'll let the pictures do the talking.
89 Dodge Colt GT
PostPosted: Mon Sep 19, 2005 10:33 pm
Very Nice its amazing what running a 60% plus Alckey will do for a car lol. looks very clean. I only know of one other car going as fast doing the same and its owned by Brad but he has AWD and its a 2G, that thing is a sleeper and a half lol
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
PostPosted: Mon Sep 19, 2005 10:36 pm
corey, you've probably talked with brad about jerry's car...
its funny, because brad become convinced the alcohol would work after tuning jerry's car up to 35lbs with the setup acting much like c16. and to think...jerry's car could make another 50-75whp if he changed the manifold's and went with a slightly crazier setup.
89 Dodge Colt GT
PostPosted: Mon Sep 19, 2005 11:25 pm
Yeah I was over Brad's house saturday for him to take a look at my car and I also got to see his meth setup, which is the exact setup I had already planned. Like I've posted before, Brad runs 36psi on pump and meth with zero counts of knock in his 2g. His next setup is gonna be boarderline retarded whenever the turbo comes in. Jerry's car looks absolutely phenomenal and I was told bout it a while back but never got to see any pics of it. Thanks for posting the pics cause his car is an inspiration for us all.
1999 Ford Contour SVT
PostPosted: Tue Sep 20, 2005 12:36 pm
Yea he called me up the day he got back from FL talking about the alcy injection. Its without a doubt the best street set-up ever. Crazy HP on tap, as long as you can keep from drainig the meth tank. I just like how clean jerrys car is, I could make so much money with that thing it would be rediclus. Brad built another guys car whose got a copy of his motor and set-up in a slightly lighter car 1G and it just went 9.94 on turbo no alchy, so kinda gives you a glimps of what brads car will run. for $500 bucks or so for a kit one of the best mods ever as long as your carful.
Corey
PostPosted: Tue Sep 20, 2005 1:20 pm
the car you are referring to must be harold's. i'm convinced alky injection is the wave of the future for those looking for the ultimate in "streetable" performance.
89 Dodge Colt GT
PostPosted: Tue Sep 20, 2005 4:41 pm
That car is AMAZING! respect to the owner.
89' Mitsubishi Mirage Turbo.
PostPosted: Tue Sep 20, 2005 5:04 pm
That bov looks huge. this car is amazing; it is very clean. Props to all who helped build it.
THE COLT
PostPosted: Tue Sep 20, 2005 5:36 pm
Minus the hood pins and the holes in the bumper, it's really a sleeper.
 Post subject: what?
PostPosted: Tue Sep 20, 2005 7:29 pm
is it for sale? :o
im not a retard, im just too slow for your taste
PostPosted: Tue Sep 20, 2005 7:38 pm
Harold just ditched the 2.4 cause he lost 3 flywheels due to vibration. Now he's running the 2.0 and pt67 that was on the 2.4. They all run the same shit, pt67s (they meaning Harold, Brad, Andre). Harold made 647 I think with the 2.0 and pt67. He was running mid 10s at MIR last weekend so it seems like the car is running decent at least, not quite the 700awhp he was making on the 2.4 but not too shabby for a 2.0.
PostPosted: Tue Sep 20, 2005 10:32 pm
Yea cuase they see brads car and want what he has, but its like he always says they have 90% of what he has, hes always got something cooking.
Corey
PostPosted: Tue Sep 20, 2005 11:01 pm
most definetly
you should see this mustang that this dude on teh megasquirt forums put together
twin p trim t4/t70 turbos - running 100% ethanol (105 octane)
made 1066rwhp recently - no nitrous, no meth
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Wed Sep 21, 2005 2:07 am
Actually, pure ethanol has an octane rating of 115. You are thinking of 'E85' (85% ethanol, 15% gasoline) with the octane rating of 105.
PostPosted: Wed Sep 21, 2005 8:46 am
550hp and he's missing a lug nut!?!?!
Regardless, that's an awesome car. It's impressive to see those kind of numbers in a 100% street setup. Badass.
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
