It is currently Mon Jun 03, 2024 7:26 pm
PostPosted: Thu Apr 15, 2004 9:49 am
I got 14b, 1 g injectos and sidemount. Running about 15psi, my car was not running good under load (no data logger to read knock).
Last night at the track I added 1 gallon o Xylene to half a tank of 91 octane cali gas. Wow - Added 6mph to my traps and lowered my et by 1s! Good enough to chase down stock evo 8s and run the same trap speeds as a STI. :twisted:
Now I just have to get my car running right on 91 cali crap.
PostPosted: Thu Apr 15, 2004 1:11 pm
That's interesting, you added 15% of xylene and went 1s faster! 8) If my quick calculation isn't wrong, you increased the octane rating to 93 at least, probably more. :D
Got rabies?
PostPosted: Thu Apr 15, 2004 1:21 pm
Seems hard to believe but where can i buy this xylene stuff?? Worth a try i guess.
PostPosted: Thu Apr 15, 2004 1:38 pm
home deopt has it, you really need some kind of oil for a buffer because the stuff is a solvent and will eat through your fuel lines.
PostPosted: Thu Apr 15, 2004 2:25 pm
The reason why it made a big difference is because my car was detonating, if your car run perfect on pump gas the additional octane will do nothing for you.
Supposedly a up to a 30% mix of toulene/xylene is ok for fuel lines and other rubberparts
PostPosted: Thu Apr 15, 2004 11:40 pm
4g61t Delinquent
why not buy C12? its like $6.11 a gallon by myhouse
I own a CSM.
PostPosted: Fri Apr 16, 2004 12:51 pm
you can run it with marvel mystery oil(the big one)
it will ube the pump and lines and what not so the xylene doesn't dry it out.
PostPosted: Fri May 14, 2004 2:31 am
HOw much is a gallon of this stuff? ANd yes, even if your car is runnign knock free, it will help, because then you can turn up the boost:)
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
HOw much is a gallon of this stuff? ANd yes, even if your car is runnign knock free, it will help, because then you can turn up the boost:) or bump up the timming
Current
08 535ix 420awhp
PostPosted: Fri May 14, 2004 3:20 am
91 octane is that it u got turbo ye isent that 2 low octane for ur car all the turbo car in australia have 2 run 92 octane n we can get it 2 96 97 octane. i do 9.9 sec 2 100km with normal petrol than i do 9.5 with with 92 octane
LAnCeR GsR 4G61
69.7KW @ 6000rpm
Genie Header
K&N Airfilter
60mm throttle body
PostPosted: Fri May 14, 2004 3:30 am
Adding Xylene or Toulene is an "Old School" trick. Quite effective, but you do need to be a bit careful as both are corrosive and over time can cause damage to sensors, fuel lines, etc.
Note: 20% Xylene will raise 92 octane to about 97. So even if your car does run well, you should notice an improvement.
This has been around for quite some time, and has some interesting info in it:
http://www.vtr.org/maintain/gasoline-octane.html
Aloha,
-Kev
Cheap, Fast, Reliable......you can only pick <b>TWO</b>.
