1600W
That is definitely a huge load for your charging system
Now, if you can spin a wrench, you can remove your alternator and take it to Canadian Tire and have them full field the thing for ya. This will tell you if it is working properly or not.
Try a search on this topic - alternator rewind/rewound I know there's stuff in here especially considering others here in Ontario have had there's rewound for major electrical installs.
(Not the most likely your problem from what you said but
Check you oil pressure to see if you have any abnormal readings as this might help you figure out if your engine was damaged.
You have too much load on you stock alternator as it is probably doing fulltime to keep up the charging duties. Best results which means no stress on the rest of the system is best had by rewinding/upgrading ti high output alternator, period - not a bad thing but maybe something you hadn't initially planned on.
Big Stereo/Electrical accessories = Bigger battery(Red/Yellow Optima style), high amp alternator, capacitor (if applicable - you got one
) just to be sure that nothing is getting stressed.
To answer why your deck shuts off - you don't get your best amperage from your alternator at low rpm's, you have to wait till they are higher.
If it is shutting off it is because you are draining your system so low that the voltage drop at the radio is too great for it to stay on.
I believe that it was posted before that this type of stress can potentially fry your ECU. Best not to fool with the devil
if you know what I mean ..... just kidding you can pull his tail and run real fast !!
IMHO
Keep us posted on your results because I personally (and I am sure that others) would like to hear back on your progress.
Tim from Ottawa
