There is a vacuum line that goes to the waste gate and there is a T and one end goes to the boost control actuator. If the T is eliminated and no line is run to the boost control actuator (like mine is), what's the problem? Just faster boost increase since the ECU can't give it to me gradually?
2nd question, How much boost can i run? I'm showing 9-10lbs of boost right now on the guage. I have a SMIC, but no ducting to get much air to it. i think I might try and move it tomorrow.
_________________ 1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
Now I ran out of fuel!!
