Hi! I already found that Diagnostic port last night, and this morning I cleaned my Air cleaner w/ high pressure air & Intake manifold w/ injector cleaner.
Good work!
Then, I put everything back & started my car and Rev it to 7000RPM, there's a lot of black/white smoke coming out thru the exhaust pipe and I drove my car going back home.
7000 REVS! Ahhhrgh! No wonder you're thinking about a rebuild. Don't rev your engine that high if there isn't a serious need to do so, and especially not when the oil is still cold! You'll seize your engine in no time then.
I keep on observing the car while driving and I noticed that it runs well & no hesitation on overtakes & sudden stop, I mean,I'm always taking a look to my RPM gauge while shifting gears and seems to me that it's working Normal now without hunting of the position. Is this true or only psychological effect after cleaning the injector?
If cleaning your injectors has helped that much - how about chaning the fuel filter?
Possibly my injectors need a regular cleaning, right?
No, in fact, you shouldn't do that too often. It can damage the fuel system (i.e. making gaskets brittle).
Have you tried to remove all the injectors & clean it one by one? How about removing the whole intake manifold & clean it?
I've never cleaned my injectors so far, there was never the need to do so. So I can't speak from experience here. However, there are shops around that are spaciallized in cleaning injectors. So far, they dont take little money for it.
As far as cleaning the whole intake tract, this is a very good idea. Our cars are over 10 years old. The dirt accumulated there alone can be the cause for idle and drivability problems. While you at it, you should check the EGR and maybe install a blockoff-plate (may be illegal where you live).
In adjusting the camshaft-sensor to advance the timing, do I also need to fool the ECU?
You're actually fooling the ECU when advancing the timing w/ the CAS. The ECU thinks base timing is at 5 degrees, but can compensate for 3 to 7 degrees w/o any problems.
What are the symptoms if I have a fault in one of the sensors of engine management like TPS, Idle-control, MAP sensor?
Actually, most of the time an error code for the respective sensor(s) will be thrown and the CEL illuminated. The 4G6x have a MAS/MAF rather than a MAP sensor.
Is there any sensor in turning the steering wheel? Because, seems to me that the ups & down of my RPM is very noticeable if turning on reverse and my car stall when I step accelerator & release while turning the steering wheel for reverse, RPM drops all the way to zero, engine quit.
Yes, there is such a sensor. It is a single wire that comes from the P/S pump. Seems like you should raise your idle speed a bit.
You are right about the engine oil that I'm using, So, on my next change oil I will use 5w-40w to minimize some noise.By the way, how many years you've been driving your car? What are your Maintenance Schedule? Have you done some engine modifications? I like one picture here that he changed the camshaft pulley to Blue color? Where do you think he bought those stuff?
I've been driving my car for 2 years now. My maintenance shedule is the one specified by Mitsubishi. My only engine mod so far are a hacked MAS (to let in more air) and a home-made catch can.
I don't know where to get blue cam pulleys. Bushur Racing or RPW maybe...?
I am also browsing COLTMANIA and I like some car in there, which is your car?
I don't have my car in coltmania's showroom. As it looks rather stock and those guys there are more interested in looks than in the car per se, my car would be considered too boring.
I ask some of the car owners but they can not speak english, that's why I'm very much happy to know you!!!! YOU REALLY HELP ME A LOT! And I can feel that this is a very good website,so many things I learned & very informative about the car as the name implies (MIRAGE TURBO/COLT).
Hey no problem buddy. Don't forget I'm not the only one on this forum. Take a look around, here are so many cool & friendy guys around, I'm also happy to be on this board.
4G61T.COM RULES!
Personal question if you don't mind, are you really from Germany? Because I am not really from MACAU, CHINA. I'm only working here for the meantime.
Yup, I'm really from Germany, even if I write rather good English. You should hear me
speak it...
