ecu and igniter http://www.4g61t.org/forum/viewtopic.php?f=26&t=40211 |
Author: | milcasten [ Thu Jun 11, 2015 7:54 pm ] |
Post subject: | ecu and igniter |
Hello, hello, I have a question, the ecu 4g61t 1.6L uses a small igniter 5 wire while 4g63t ecu uses a larger igniter 6 lines , why the difference? Will this interfere if ecu exchange difference ? |
Author: | 89Mirageman [ Thu Jun 11, 2015 10:04 pm ] |
Post subject: | Re: ecu and igniter |
The 90 dsm's used the 5 wire PTU as well. It's because the coil is different between the two. |
Author: | milcasten [ Fri Jun 12, 2015 10:24 am ] |
ok, thank you, you can exchange ECU from CSM 4g61 and DSM 4g63? |
Author: | 89Mirageman [ Fri Jun 12, 2015 1:37 pm ] |
A 90 turbo dsm ecu will work if you swap out the maf and injectors. 91-94 would require the same mods as putting a 90 ecu in a 91-94 dsm. |
