Front left wheel shakes bad on left turns and any bumps http://www.4g61t.org/forum/viewtopic.php?f=26&t=39490 |
Author: | modicaUSMC [ Mon Dec 22, 2014 8:15 pm ] |
Post subject: | Front left wheel shakes bad on left turns and any bumps |
So guys I know it has been beaten to death but I'm still confused with searching for front lower control arm bushings for a 91 mirage sedan. I believe the bushings are beyond shot because I had a car with a bad LCA before and it did the same thing. I only have 90 miles on the engine and I wanna break it in but it's dangerous to drive as is 1: can I use any Hyundai elantra bushings? 2: is there a part number for the non turbo sedans LCA bushings? (Mitsu order at a dealer?) 3: can any other bushings be shaved to work? (1G DSM?) All you guys got hatches and I'm over here with the granny sedan haha thanks as always |
Author: | xxNocturnalxx [ Tue Dec 23, 2014 10:59 am ] |
Post subject: | Re: Front left wheel shakes bad on left turns and any bumps |
This thread should help you out.. http://www.4g61t.org/forum/viewtopic.ph ... t&start=15 |
Author: | Keane [ Tue Dec 23, 2014 11:45 am ] |
Dont rule out a bad wheel bearing or a worthless shock either i would inspect the bushings before swapping them out |
Author: | modicaUSMC [ Sat Jan 03, 2015 11:27 pm ] |
I'll check the wheel bearing for sure again and the K-sports should be ok but I'll check their compression. For a non turbo mirage sedan do the hyundais LCA bushings work as a replacement? |
Author: | j2dapo [ Sun Jan 04, 2015 3:44 pm ] |
I believe they do, but I've haven't tried it yet. What I did was order some front LCA bushings from rockauto for a 92 elantra. I crossed referenced them with a CSM. For the rear LCA bushing follow the link posted above. |
Author: | modicaUSMC [ Sun Jan 04, 2015 3:49 pm ] |
Quote: I believe they do, but I've haven't tried it yet. What I did was order some front LCA bushings from rockauto for a 92 elantra. I crossed referenced them with a CSM. For the rear LCA bushing follow the link posted above.
Thanks I've been trying to navigate the link but it's a little confusing at times. Don't have time to wait months though because my girl is driving the Evo and my new DD is the 91 and I need it to be safe
Author: | modicaUSMC [ Mon Jan 05, 2015 1:18 am ] |
so after digging around on super pros website it looks as though the 92-95 mirage front LCA bushings will fit the non turbo 91 LCA's and the 93 Hyundai elantra rear LCA bushings will also pair up, going to order them and install them next weekend, ill come back to see how it all works |
