What wheel spacer to use to clear hub bolts? http://www.4g61t.org/forum/viewtopic.php?f=26&t=36657 |
Author: | xxNocturnalxx [ Wed Aug 01, 2012 3:54 am ] |
Post subject: | What wheel spacer to use to clear hub bolts? |
I bought this type but they do not work.. http://www.ebay.com/itm/JDM-KICS-KYO-EI ... 73&vxp=mtr What spacers are you guys using? |
Author: | 89Mirageman [ Wed Aug 01, 2012 7:51 am ] |
Post subject: | Re: What wheel spacer to use to clear hub bolts? |
Those are the ones I used with no issues. Bought them from a local tire/wheel guy. Maybe mine were slightly thicker. I want to say that the ones he sold were 4 or 5 lug specific though. |
Author: | xxNocturnalxx [ Thu Aug 02, 2012 1:00 am ] |
Ok, cause these are 4 and 5 lug universal but the bolts don't fit through any of the slots lol I'll try a different set thats 4 lug specific. |
Author: | 89Mirageman [ Sat Aug 04, 2012 2:11 pm ] |
That would be the difference then. Seems like mine had 4 oval holes for the lugs and then 4 square holes in between those if that makes sense. |
Author: | xxNocturnalxx [ Sun Aug 05, 2012 2:02 am ] |
Yes, it does, thank you. If you get a chance can you post a web page ad of them so I can make sure it's exactly what you have? |
Author: | 89Mirageman [ Sun Aug 05, 2012 6:13 am ] |
They were very close to this if not identical. The local guy that mounted my tires happened to sell them. ![]() |
Author: | xxNocturnalxx [ Sun Aug 05, 2012 6:16 am ] |
Cool, and did you match the center bore or just get oversized ones? Also, 8mm thickness? |
Author: | xxNocturnalxx [ Sun Aug 05, 2012 6:22 am ] |
http://www.ebay.com/itm/Two-5-16-Thick- ... 66&vxp=mtr |
Author: | 89Mirageman [ Sun Aug 05, 2012 11:46 am ] |
The centerbore was not matched for sure, I just eyeballed them and tightened the lugs a little until the wheel held it on straight. 8mm sounds about right for the thickness. |
