| clutch flywheel options for km210 http://www.4g61t.org/forum/viewtopic.php?f=26&t=32756 |
| Author: | keith- [ Wed May 26, 2010 1:49 am ] |
| Post subject: | clutch flywheel options for km210 |
making sure i have this straight before i go ordering parts i can use a fwd dsm clutch and fly wheel with my km210 trans? and or an awd dsm clutch and fly wheel??... iv seen it posetd up but im too lazy to search it right now |
| Author: | Johnny_B. [ Wed May 26, 2010 2:48 am ] |
| Post subject: | Re: clutch flywheel options for km210 |
I'm running a sachs disc and pressure plate with an OEM 4g63t fly wheel on my KM210 tranny and no issues so far. Just match clutches with fly wheel and you should be good. Unless my car is a freak of nature and some how works... |
| Author: | Flying Eagle [ Wed May 26, 2010 7:01 am ] |
I have a factory KM210 in which I had previously installed a lightened factory 215mm flywheel, and CFDF clutch (was slipping due to PO abuse or my new found power/torque in combination). I bought this DSM 225MM ACT 2100 clutch and pressure plate combination. http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem= ACT 2100 HD CLUTCH KIT TALON ECLIPSE DSM MB1-HDSS Lightweight flywheel that I mated it to. http://www.extremepsi.com/store/custome ... 646&page=1 Fidanza Lightweight Aluminum Flywheel : Mitsubishi Eclipse 90-99 Turbo #16363 THIS PART # FDZ-161651 Flywheel bolts for which you need to purchase a 12 point socket to install. ARP Pro-Series Flywheel Bolt Kit (8-pieces): Mitsubishi Eclipse 90-99 #21611 ARP-203-2801 The flywheel bolts are actually 7gte bolts as labelled on the package but they are the correct depth for the thicker flywheel material. Of course you can always use a stock clutch and flywheel combination, 225mm FWD 6 bolt and it will fit the starter and crank with no modifications. |
| Author: | CaptainTonus [ Wed May 26, 2010 9:42 am ] |
I run a ACT 2100 kit for a 90-99 DSM and a stock 6-bolt FWD DSM flywheel. Works great. If I ever change it I will probably get another 2100, and maybe a lightened flywheel. |
| Author: | j2dapo [ Thu May 27, 2010 8:11 pm ] |
Youll need a turbo fwd flywheel for a km210, not a awd flywheel. Clutches are the same for fwd/awd. |
| Author: | ColtiXim [ Tue Jun 01, 2010 3:36 pm ] |
look here http://www.4g61t.org/forum/viewtopic.php?f=6&t=31791 |
| Author: | galant1517 [ Sun Jun 20, 2010 9:25 pm ] |
Its been a few years, but I seem to remember that a an AWD DSM flywheel and clutch fits the km210 perfectly. The FWD turbo DSM flywheel has too large of ring gear to fit inside the bellhousing. All turbo DSM clutches are interchangeable, so when ordering a clutch just specify turbo model. |
| Author: | CaptainTonus [ Mon Jun 21, 2010 12:06 am ] |
Quote: The FWD turbo DSM flywheel has too large of ring gear to fit inside the bellhousing.
You can use a FWD turbo DSM flywheel too, it fits.
| Author: | galant1517 [ Mon Jun 21, 2010 12:24 am ] |
Quote: Quote: The FWD turbo DSM flywheel has too large of ring gear to fit inside the bellhousing.
You can use a FWD turbo DSM flywheel too, it fits.Like I said, its been a few years, so it wouldn't surprise me if I'm wrong. |
