It is currently Sun Nov 02, 2025 9:52 pm
 Post subject: Vent Selector Switch
PostPosted: Wed May 12, 2010 7:29 am
I don't know if this is commmon with these cars or not. I couldn't find much by searching. My heater controls all work except for the vent selector switch (the one that lets you select floor, dash, or defrost). This is a problem as it's raining and the glass keeps fogging up. Is this a common issue? Anyone know what would cause this not to work? I'm sure I can figure it out when I tear into it but any preliminary guesses would give me a direction to go in. Thank you.
 Post subject: Re: Vent Selector Switch
PostPosted: Wed May 12, 2010 7:31 am
My guess is a broken clip or the cable popped off.
PostPosted: Wed May 12, 2010 8:05 pm
It's an actual cable that goes from the selector to the swingarms on the hvac box. They can pop out of the guides, start checking under the dash with a flashlight.
PostPosted: Thu May 13, 2010 12:40 am
You might be able to see part of it better if you remove the glove box and the plastic piece behind the glove box.
- Works in da bush
