http://www.4g61t.org/forum/
Vent Selector Switch
http://www.4g61t.org/forum/viewtopic.php?f=26&t=32668
Page 1 of 1
Author:  forced4dr [ Wed May 12, 2010 7:29 am ]
Post subject:  Vent Selector Switch
I don't know if this is commmon with these cars or not. I couldn't find much by searching. My heater controls all work except for the vent selector switch (the one that lets you select floor, dash, or defrost). This is a problem as it's raining and the glass keeps fogging up. Is this a common issue? Anyone know what would cause this not to work? I'm sure I can figure it out when I tear into it but any preliminary guesses would give me a direction to go in. Thank you.
Author:  89Mirageman [ Wed May 12, 2010 7:31 am ]
Post subject:  Re: Vent Selector Switch
My guess is a broken clip or the cable popped off.
Author:  Mechacode [ Wed May 12, 2010 8:05 pm ]
It's an actual cable that goes from the selector to the swingarms on the hvac box. They can pop out of the guides, start checking under the dash with a flashlight.
Author:  colt200 [ Thu May 13, 2010 12:40 am ]
You might be able to see part of it better if you remove the glove box and the plastic piece behind the glove box.
https://www.phpbb.com/
