It is currently Wed Oct 29, 2025 7:28 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
 Post subject: is it a 4g63Tor a 4g61T?
PostPosted: Sat May 01, 2010 11:29 am
Hello everyone i just got a 89 mirage with a "4g63t" as per the previous owner, but i checked the side of the head and the numbers engraved are g6 and under it it has 10 i dont have a clue what this means. Becuase the head that i had laying around wich i took off my galant vr4 has a 20 engraved on it. So this is where the question comes what head do i have?????? Can anyone help me??
PostPosted: Sat May 01, 2010 1:06 pm
I am not sure if there is a visible difference from the outside of the 1.6 and 2.0 blocks. The bolt on stuff will be different like the intake and exhaust ports will be smaller on the 1.6, smaller fuel injectors and throttle body on the 1.6 and I think they have a different water pipe under the exhaust manifold.
The head on my 4g63t engine does have 20 on it too, I cant remember what the 4g61t engine I took out had on it.
- Works in da bush
PostPosted: Sat May 01, 2010 1:10 pm
IT HAS 550 INJECTORS AND A DMP MANIFOLD WITH A EVO 16g i dont wannatake all that out just to check the block numbers but it does have a polyurathane engine mount on the back all other mounts look stock and it has a 2.0 valve cover but i read they all fit each other. thanks for the info though i appreciate it
PostPosted: Sat May 01, 2010 2:35 pm
Take a picture of the water pipe that goes across the front of the block and post it.
PostPosted: Sun May 02, 2010 12:04 pm
Also the VIN should be stamped on the top of the block right where it meets the head on the transmission side. If it matches the VIN on the car of course its a 1.6, if its different a free check on Carfax will let you know what it came out of.
PostPosted: Sun May 02, 2010 12:52 pm
Measure from the oil pan flange to the head/block mating surface.
PostPosted: Sun May 02, 2010 1:52 pm
post clear pictures of the waterpump :)
or if you're bored count the cogs on the timing belt :)
PostPosted: Sun May 02, 2010 6:43 pm
5 shmidt heads to the first person answering this correctly.
PostPosted: Sun May 02, 2010 6:50 pm
I'll admit I don't know how many cogs are on either belt, but I will send 5 Schmidt Heads to whoever guesses correctly, and 6boltcolt verifies lol. :yawinkle:
PostPosted: Sun May 02, 2010 7:42 pm
Front of the block near the power steering area, there is a flat surface with some form of displacement stamped there. IIRC.
PostPosted: Sun May 02, 2010 8:56 pm
It will say either 4G61 or 4G63, but it's usually so caked with grease and oil residue that you'll never see it.
PostPosted: Mon May 03, 2010 9:24 am
Thanks everyone i will check that stamp near the power steeriing and take pics today to post them thanks for the advice
PostPosted: Mon May 03, 2010 9:25 am
But I guess that number on the head does'nt mean anything??????
PostPosted: Mon May 03, 2010 9:42 am
The head could have been swapped at any time.
PostPosted: Mon May 03, 2010 10:10 am
Correct. Most 1.6 heads actually say 1.8 on them.
