Hello GUYS,
I already adjusted my Accelerator-cable thru this two(2) adjusting bolt, and here are the scenarios;
1. Engine temperature - COLD
2. Loosen 2 adjusting bolt & move the plate inward until I feel the tension on the cable.
3. Tighten the adjusting bolt.
4. Start the engine- REV 2500RPM ( too high...!)
5. Loosen again the 2 adjusting bolt and slightly tap the plate outward til the 1500RPM, tighten the bolts.
6. Drove the car, engine running very well.
Noticeable effect;
1. When I release the accelerator for the stop, engine RPM stays on 1200. After few seconds, RPM drop to 700-750. ( I like this......!)
2. As soon as the engine gets hotter, I noticed that everytime I step on the brake pedal, the RPM gauge also drops more than 500RPM. (WHY?)
3. On fully stop, I step on the brake pedal & RPM drops to zero.(WHY?)
4. Using signal-lights, RPM also follow the tick of the lights.(WHY?)
5. Using headlights, RPM stays on 700-750, steps on the brakes-No effect to the RPM gauge. (WHY?)
WHAT ARE THE NEXT THINGS I SHOULD DO & CHECK TO CORRECT ALL THIS PROBLEM? NEED ALL YOUR HELLLLLLLLLLLLLP!
( I'm getting HAPPY now little by little after I corrected the accelerator- cable problem and the engine RPM is not going down right away everytime I released my foot on the accelerator pedal)
NAMRON
88 COLT GTi-16V
