Shocks http://www.4g61t.org/forum/viewtopic.php?f=22&t=4382 |
Author: | tension5072 [ Tue Jun 17, 2003 3:28 pm ] |
Post subject: | Shocks |
Aight, when Im turnin my mirage kinda quick, it starts to tilt from the shocks being so loose. What kind of shocks are available to stiffen the suspension significantly and maybe lower it a lil. -Jason '91 Mirage 4g15 |
Author: | colt-r-old [ Tue Jun 17, 2003 3:30 pm ] |
Post subject: | |
i have eibachs on my car, i can email it to you so you can see hwo it looks. look on mmrusa.com i know intrax and B&G make lowering springs for the colt. it will be listed as colt 200e its the same car as the gt and 200 gt. Just different models had different options:P |
Author: | summit1.6 [ Tue Jun 17, 2003 3:31 pm ] |
Post subject: | |
WELCOME TO THE TEAM!!!! Im gettin th TeinSS as you know lol... |
Author: | m435tro [ Tue Jun 17, 2003 5:04 pm ] |
Post subject: | |
Quote: i have eibachs on my car, i can email it to you so you can see hwo it looks.
Would this B&G lowering spring for 200e will also fits 4G15?
Author: | endlessMyk [ Tue Jun 17, 2003 5:40 pm ] |
Post subject: | springs/shocks/etc |
Hey-I just put on some Dropzone 2" lowering springs for the 1st gen eclipse. When doing that it was discovered that I need new shocks. ANy suggestions??? |
Author: | Guest [ Wed Jun 18, 2003 10:54 pm ] |
Post subject: | |
Koni's |
Author: | colt-r-old [ Wed Jun 18, 2003 10:57 pm ] |
Post subject: | |
Quote: Quote: i have eibachs on my car, i can email it to you so you can see hwo it looks.
Would this B&G lowering spring for 200e will also fits 4G15?look on mmrusa.com i know intrax and B&G make lowering springs for the colt. it will be listed as colt 200e its the same car as the gt and 200 gt. Just different models had different options:P |
Author: | LILEVO [ Wed Jun 18, 2003 11:05 pm ] |
Post subject: | |
Well I just tried to put dropzone springs on my car and only the front was feasable. The rear tires were basically at or underneath the wheelwells and the fronts were a good two inches off the tires. So I stuck with the stock AWD springs in the rear with AGX and front dropzones with AGX. WoW! does the car handle now. I can't believe the difference from cut AWD springs and blown shocks ![]() |
Author: | dragstr4g61t [ Thu Jun 19, 2003 1:27 pm ] |
Post subject: | |
Are the AGX a shortened strut rod so they ride in there designed range? |
