It is currently Mon Jun 03, 2024 10:18 pm
PostPosted: Sun Dec 24, 2017 4:03 pm
Cannot for the life of me find any diagram of where the fuel pump relay is on my '88 Colt DL.
Doesn't seem to be a fuse dedicated to it based on the fuse box labels.
PostPosted: Tue Dec 26, 2017 11:23 am
I could be wrong, but the MPI relay used in later models is very similar to this, assuming you have a 1.5L car for illustration purposes: https://www.rockauto.com/en/catalog/mit ... relay,3292
These are the electrical schematics that most closely match your car hopefully.
http://4g61t.org/archive/manuals/87%20C ... chematics/
PostPosted: Thu Feb 08, 2018 7:56 am
I can dig it out.i have a print copy of the fsm.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Thu Feb 08, 2018 12:04 pm
The relay is located under the dash up in the driver side kick panel. Connector b13 according the fsm wiring map. Look for the connector that has the same wires as shown in the schematic I attached.
What is the problem you are looking to fix?
Is the Colt DL a Turbo model?
DRCOLT
PostPosted: Thu Feb 08, 2018 12:06 pm
Let me know if links work for you.
I can also scan them and email them to you.
Pm me for email.
DRCOLT
