headlight switch problem http://www.4g61t.org/forum/viewtopic.php?f=22&t=41041 |
Author: | mikbik [ Wed May 24, 2017 10:20 pm ] |
Post subject: | headlight switch problem |
I need help does anyone know how can I make my headlight switch to work. I replaced my headlight column switch ones w/ cruise control but the headlight doesnt work same as a turn signals but the wiper switch work flawlessy. what could be the problem I dont mind making the cruise control to work I just need the headlight and turn signals. Are there wiring diagrams or could this be the a board problems? Btw, the high beam work, but the park light and low beam and the turn signals dont work |
Author: | mitsubishikid [ Sun May 28, 2017 7:34 pm ] |
Post subject: | Re: headlight switch problem |
The turn signals in my colt had the same issue, I took the whole unit out of my car, eventually to reveal the circuit board that the turn signals activate off of, then I noticed the contacts had some corrosion on them, so I lightly sanded them to metal again, then I put a light coat of dielectric grease over the moving parts. so far no issues been about a year hope this helps. you might have other problems, but thought I'd share what worked on my car. |
