Fifth gear end case issue http://www.4g61t.org/forum/viewtopic.php?f=22&t=38737 |
Author: | Flying Eagle [ Sun Apr 13, 2014 7:14 pm ] |
Post subject: | Re: Fifth gear end case issue |
Flip the shell for fifth. It might have an off center area for the shifter fork fingers. Is it possible it's flipped? The FSM shows a bunch of angles for each gear shell, it looks pretty easy to flip. When the remainder of the fifth gear is installed, it may put things out of alignment. Quick to check, it may be listed on the lilevo site. |
Author: | SPOOLD [ Sun Apr 13, 2014 9:06 pm ] |
I made sure and left the fifth gear set exactly as removed so I didn't mix things up. I removed the little dowels and cleaned those up and played with the thin tinny ring that attaches to the cover and sits against the brass synchro ring. Something seemed to help and it feels like it's engaging fully now. Maybe I was just being a wuss and didn't want to force it. We'll see how it goes. |
Author: | Flying Eagle [ Mon Apr 14, 2014 6:00 am ] |
You can remove the end case with the trans in the car too. So, not a big worry that way. |
