hi guys,
i have had the fuel filter in the oil breather line for quite sometime now about 2 months. i did it along with many other things. ever since then my car has not felt as good. the other day i was giving it some $%# and stopped at some lights only to find that i had smoke pissing out of my engine bay!! i stopped around the corner and found that the dip stick had been pushed up and oil had sprayed my whole engine bay and was smoking off the exhuast manifold! any way after cleaning it up i tryed a few different things and as soon as i replaced the oil filter with a straight peice of hose the car ran so much better. i even cut open th eiflter and it was so clean inside it could not have been blocked so whats going on? has any one else had this problem? some how it was pressurising my crank case.
My guess is that even the small restriction that the filter would place in the line is just far too much for a system that was never designed to have a restriction in the first place. Take it out IMO.
