| Boost gauge install question http://www.4g61t.org/forum/viewtopic.php?f=22&t=37867 |
| Author: | joemoto [ Sat Jun 15, 2013 10:19 pm ] |
| Post subject: | Boost gauge install question |
Normally I would run the hose through the rubber gasket at the steering wheel , but there does not seem to be near as much room as the 2g GSX or Galant VR4. Is it my imagination that there is not enough room for my boost line? I will be wanting to install an oil gauge soon as well and it looks too tight. Is there another route to use? I wish I would have noticed this earlier when I had the motor out and put a manual steering rack in as well. Thanks - Joe |
| Author: | Flying Eagle [ Sun Jun 16, 2013 7:16 am ] |
| Post subject: | Re: Boost gauge install question |
Likely there is more room at the grommet that brings in the ECU wiring near the brake booster. Alternatively if you use a hole saw to cut a hole in the firewall, prepare for multiple layers of metal at weird angles. I know I brought in my boost gauge somehow last time, so there must be an option closer to the steering column. |
| Author: | Coltsfan [ Sun Jun 16, 2013 9:40 am ] |
There's a large grommet for the speedometer cable. |
| Author: | Flying Eagle [ Sun Jun 16, 2013 10:02 am ] |
That's it! Haha. |
| Author: | joemoto [ Sun Jun 16, 2013 12:31 pm ] |
Quote: There's a large grommet for the speedometer cable.
I will check it out , thanks.
| Author: | Mechacode [ Sun Jun 16, 2013 4:38 pm ] |
That's where my wire harness and tubing went through.
| Author: | joemoto [ Sat Jun 29, 2013 6:08 pm ] |
That worked for me . Thanks |
