It is currently Sat Oct 25, 2025 6:30 pm
PostPosted: Sat Apr 27, 2013 9:09 pm
on a stock 61?
looking at the gates power grip t165 ..and the melling bo165. couldn't find the gates blue racing one for the 61..just the 63.. i just want something better than the stock autozone ones.
thanks
PostPosted: Sun Apr 28, 2013 1:51 am
I heard a rumor that stock EVO 9 timing belts are made of Kevlar from the factory. It should have the same number of teeth. Just sayin'
PostPosted: Sun Apr 28, 2013 2:56 am
Regular Gates would be a good option if you don't find a good performance one for the 61t
PostPosted: Sun Apr 28, 2013 10:39 am
My bad. If you need one for the 61t, I'd just run whatever you can find, because hardly anyone will have them available.
PostPosted: Sun Apr 28, 2013 1:13 pm
Call JNZ for the OEM one.
MD133116 or MD145714 Part number
I have read bad story with aftermarket like Contitech on Tuners
PostPosted: Thu May 02, 2013 10:21 pm
Been running Contitech for years. NEVER an issue. Same with Gates. Never had an issue with the 151 tooth 1.6L belts from either company. They are just as reliable as the Mitsubishi belts.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Thu May 02, 2013 11:02 pm
I've run Gates belts on everything I've done timing belts on, no issues so far. About to stick one on a 2.7 v6.
PostPosted: Fri May 03, 2013 7:01 am
I too run Gates belts and Gates coolant hoses.
PostPosted: Sat May 11, 2013 8:15 am
OEM all the way. I wouldn't trust my engine with anything else.
