CSM roll cage http://www.4g61t.org/forum/viewtopic.php?f=22&t=36605 |
Author: | 92colt200e [ Fri Jul 13, 2012 3:17 pm ] |
Post subject: | CSM roll cage |
Is anyone aware of any type of pre fabbed roll cages that require to be welded in for the CSM? Is there any option? Or just complete custom build. |
Author: | CSM Shaun [ Fri Jul 13, 2012 3:42 pm ] |
Post subject: | Re: CSM roll cage |
Fox body Mustang cages work great in 1gs and are inexpensive from Jegs. Your best bet would be to get measurements for the main hoop and go from there. |
Author: | 92colt200e [ Fri Jul 13, 2012 5:49 pm ] |
Never knew this existed. http://www.lpiracing.com/Autopower-U-We ... 177077.htm Anyone have any experience ? |
Author: | Flying Eagle [ Fri Jul 13, 2012 7:13 pm ] |
Never seen that avenue available before, so this is good news. First thought was the Fox body cages as mentioned above. 100 lbs. |
Author: | slowdsm [ Fri Jul 13, 2012 7:41 pm ] |
thats only the front section .. you would still need the hoop and rear section. Steve |
Author: | 92colt200e [ Fri Jul 13, 2012 8:53 pm ] |
Yea I know. They have that section available as well. Basically It seems you have potential for a full weld in kit CSM specific with them ![]() |
Author: | CSM Shaun [ Fri Jul 13, 2012 8:54 pm ] |
For how much? |
Author: | xxNocturnalxx [ Sat Jul 14, 2012 1:00 am ] |
I'm liking that a lot, not that I need one right now lol |
Author: | 92colt200e [ Sat Jul 14, 2012 6:38 am ] |
![]() The front portion which is the u weld kit, is on sale for $413.95 U-Weld Front Cage Kit This cage kit welded to an Autopower roll bar makes a race legal 6mounting point roll cage. Autopower will choose tubing size when youplace your order. Most Kits Include: - 2 forward support braces - Top windshield cross tube - 4 door guards - Under dash bar - 4 top corner gussets - All necessary installation and mounting hardware with back-up plates is included. ![]() The race roll bar is on sale for $531.95 Street Roll Bar This roll bar will give your street car a performance look and style. - In most cars rear seats and/or convertible top remain in place and useable. - This roll bar is made of 1.750 x .120 DOM mild steel tube. - All necessary installation and mounting hardware with back-up plates is included. ![]() There is also a bolt in kit for the CSM on sale for $888.95 Bolt-In Roll Cage It's designed to quickly and easily transform your street car into a race legal competition car. This cage closely conforms to your car's interior, allowing quick entry & exiting. It uses precision fit, 6 mounting point, slip-tube and bolt-in design. This cage is approved by SCCA and NASA for open road racing and drifting events. The best fitting pre-fab cage you can buy. All cages made to order. - SCCA & NASA legal for club racing. - Top of the line in fit and construction. - These cages are made to order, allowing for tube size and type to be selected. - Diagonal cross brace and horizontal brace are a permanent weld-in design. - Autopower will select tube size and type for your needs. - All necessary installation and mounting hardware with back-up plates is included. - Most Bolt-In Cages are made of 1.50 or 1.750 x .120 DOM mild steel tube. - Picture with Driver's Safety Net, not included. |
Author: | MoWGLi [ Sun Jul 15, 2012 12:10 am ] |
ioport racing lists cages for our cars also. |
Author: | mirage760 [ Sun Jul 15, 2012 12:01 pm ] |
seems legit but can't trust it till someone buys one |
Author: | modicaUSMC [ Fri Aug 10, 2012 1:10 am ] |
The question I have is will it fit in a 3G sedan?? If so than I'm all over one |
Author: | xxNocturnalxx [ Thu Aug 22, 2013 6:02 am ] |
Anyone try any of these yet..? http://www.ioportracing.com/Merchant2/m ... de=AP680DC |
Author: | aaronsbig16g [ Sat Aug 24, 2013 5:57 pm ] |
To get the best fitting cage a custom made one is the way to go, imo. But I'm kind of spoiled there a ton of local shops around me where I can get one done. |
Author: | biglady112 [ Wed Aug 28, 2013 8:14 am ] |
I used a universal mustang kit. I had to cut and notch every bar anyway. So it fit like wanted . There was more than enough material to be tailored to your liking. |
